Reply 900 of 57744, by feipoa
- l33t++
wrote:got a couple boards off of ebay. I swore to myself that I wouldn't build a 486, but it looks like I'm going to be building two! Well 1 & 1/2.
looks like a top of the line 486 motherboard: http://www.ebay.com/itm/270912095100 looks like it has everthing I want in a 486.
I also have a "super" 386 setup. A sweet setup with scsi, 32mb of ram. I thought I was DONE with it. Until I found this guy: http://www.ebay.com/itm/270912174499 Yes. its a 386 board! with VLB! and a 386>486 upgrade chip! Which means I need to put a pod83 into the other board to balance my karma...
Wow, you totally ripped that guy off on the 486/IBM 5x86c auction. Congratulations! He probably could have gotten $25 for the board alone, and another $20 for the CPU. I like seeing the 9 DIP-32 sockets as it implies it may work with 1024 KB of L2 cache. The main fault I see is the lack of a PS/2 port header, but if it works with 1024 KB of cache, I suppose that is a balanced trade-off.
If you are gunnin' for a prized IBM 5x86c-133 (2 x 66) be forewarned that of the two IBM 5x86C-100HF chips I own, only one of them was stable at 133 MHz, with a voltage as low as 3.7V! The other chip worked well only at 2x60 (120 MHz).
I'm surprised I didn't see this auction and bid on it... oh, I see why now, he only ships to the United States. He could have greatly increased his profit margin by selling internationally.
As for the 386 board -- looks promising. Unfortunately it didn't come with the FPU. If you don't already have one, I think there's a rip-off USA-only auction for the Cyrix 40 MHz FPUs at $29. Very curious how it has no L2 cache.
Fantastic finds!
