First post, by Jakodemus
I need some help configuring this sound card for Dos. Does is need some drivers to work? I can only find win3.1-> drivers.
http://uk.ts.fujitsu.com/rl/servicesupport/te … MMPro16IIIS.htm
Reply 1 of 2, by Davros
do you have a game that contains setsound.exe
try that
perhaps msd.exe will tell you what irq's ect its using its a sbpro compatible so it could just be a case of getting the set blaster line right
ps: the win 3.1 drivers may contain the dos drivers
Reply 2 of 2, by Malik
Try this file attached below. It contains two folders - Drivers and Utility.
    MMP16III.zip
    358.12 KiB
    277 downloads
