First post, by megatron-uk
This is the EA 'CD Rom Classics' release.
There are seperate sound/music options - I'm trying to configure the game to work with SB for effects and standard MIDI port 330 for music.
However, there doesn't appear to be a way to set the base address of the MPU401 interface when you select the 'manual configuration option'. I presume it's looking at the SB environment variables as the music test plays through my XR385 card (set at base 0x300), rather than my MT32 or SC55 (standard 0x330).
Any ideas?
https://www.target-earth.net
Reply 1 of 1, by AdamP
I have an option to set the I/O address, though I suppose your version might be different.
Try editing the mdi.ini file and setting the port there.
