First post, by Floppy
Hello folks i want to try to install Win98 i have a genuine Disc for that and although i found the tutorial hereGuide - Windows 95 on DOSBox 0.74
i had once almost close to installing it but then windows :something like this:
http://img35.imageshack.us/img35/7144/error1pn.png
So now i want to make a bigger flat hdd space somewhat like 1.5 GB, where i can copy all the contents of Win98 disc and then try again, so i had made a flat hdd like 1.4 GB and used MS-DOS boot disk to give a partition using fdisk: which i did but it would show only 492 MB in size and i am puzzled and as i had followed the tutorial , which described a formula and only to give the amount of cylinders: which i did while making the flat HDD.
Please this : http://www.dosbox.com/wiki/IMGMOUNT#Hard_disk_images
Please see the screenshots : what it would look like:
http://img832.imageshack.us/img832/1531/cimg1500mb.png
http://img259.imageshack.us/img259/5356/cimgafterfdisk.png
http://img835.imageshack.us/img835/8532/cimgsize.png
Hard disk images
The "-size" parameter (required to to create bootable hard disk images)
Didn't understand the "512,63,16,142" part?
All you really need to know is that the formula is always:
-size 512,63,16,X
Hope now it is clear as to what i am trying to achieve, but fdisk doesn't show that amount of space and i had made a 900 MB disk where fdisk showed only 235 MB.
So where did i go wrong here, i am not able to assign the correct size for the image hdd i created, help out please.
I want to try my hands at installing WIN ME and WIN 2000 too.
Reply 1 of 7, by wd
Rank DOSBox Author
DOSBox Author
Use bochs or any virtualizer.
Reply 2 of 7, by Floppy
I just can't believe that my thread was locked but i can't just reason, after making all these effort to make my problem be know properly.
My topic was closed , but why can't someone help me give a asuggestion....
Reply 3 of 7, by leileilol
DOSBox.
Debian's fucked
Reply 4 of 7, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
You are persistent in not getting it, right. No Windows 9x support means that asking for help with win9x will get closed...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 5 of 7, by eL_PuSHeR
And you already got an answer: Use a virtualizer.
Reply 6 of 7, by Floppy
I can do that , but sometimes running Win98 in Virtual mode does tend to slow down the OS and it is not so snappy like the real one: and i believe running it in DOSBOX would certaily make it like a real deal, i think the developer should give a little serious thought and give a new name like DOSBOX pro where virualization is possible at least for running older version of WIn and Mac.
Reply 7 of 7, by wd
Rank DOSBox Author
DOSBox Author
No. There are enough virtualizers out there.
