Registered Descent fully supports most VR Head Mounted Displays. […]
To enable support for a given VR device, see the command line help.
During the game, the following keys are used for VR settings:
Enter: Toggles HUD info on/off.
Alt+Z: Centers the VFX1 head tracking.
Shift+F5 or Alt+V: Toggles the Cybermaxx between monitor and headset.
Shift+F6: Toggles high/low resolution modes. There are 4 modes, which
are combinations of cutting the vert/horz resolution in half.
Lowering the resolution can improve framerate dramatically.
Shift+F7: Reverses left/right eye.
Shift+F8: Toggles head tracking sensitivity. There are three settings,
low, normal, and high.
If you have questions about the headsets, the manufacturers can be
reached at the following numbers:
- VFX-1 Head Mounted Display, by Forte Technologies, Inc.
tel: 716-427-8595
fax: 716-292-6353
- CyberMaxx HMD, by VictorMaxx Technologies, Inc.
tel: 1-800-279-6880
fax: 708-267-0037
- I-Glasses, by Virtual I-O
tel: 800-646-3759
fax: 206-382-8810
net: vio@vio.com
- 3D-Max shutter glasses
US: Chinon America:
tel: 310-533-0274 Ext 570
fax: 310-533-1727
Europe: Kasan
tel: 011-46-18-187777
