Current specs on this build are:
Tyan S1832D Rev. B
Dual PIII 600Mhz SL3JT
4x 256mb Kingston PC-100 Unbuffered
Nvidia GeForce4 MX440
Voodoo2 12mb (Diamond Monster 3D)
Sound Blaster Live!
4GB Fujitsu
80GB WD Caviar
Antec Earthwatts 380
Anteck NSK-4482B
I'm planning on getting another Voodoo2 12mb in the future for this build. Haven't done much other than a tabletop test with the mobo and a few key components, I'll be putting this together sometime this month. Probably going to dual-boot with Windows 98SE and 2000 Pro. Might play around with some form of Linux install at some point as well.
Is the Voodoo2 pass through cable just a standard VGA male-female? The card did not have one and I'm wondering if I'll be able to sub in a standard VGA with a male-female adapter instead.
On another note, does anyone have any experience with BIOS modding? I've got an MS440GX and a pair of 700Mhz 1Mb PIII Xeons for another build, and it turns out that this board is a Gateway OEM, which is a problem. The board boots up and recognizes these as "400Mhz" Pentium Pros, but disables the onboard cache. I'd like to max this board out if possible, there's a guy selling Quantum3D Obsidian2 SBi's for a pretty decent price on ebay, and I'd love to get one for this build.
I've been looking for an ASUS XG-DLS, or one of the Supermicro boards, but this board was the only one I found that actually came with the retention bracket.
