Trying to find out about a particular AWE32
First post, by commodorejohn
I'm looking at getting an AWE32 CT3670, but before I go dropping money on that I want to make sure it's got the actual OPL3 core and not the CQM core; I've had too many annoying experiences with "compatibles" that are just different enough to botch the sound on some song or other completely. I'm told that the CT1747 chip is the one that has the OPL3 core, but the chip the seller sees on the board is CT1745A - does this mean it doesn't have it?
Reply 1 of 29, by AdamP
Post removed because it was a load of tosh
Reply 2 of 29, by commodorejohn
Huh, I was misinformed on that, then. But this card doesn't have the CT1747 anyway; according to the seller, "The chips that I found are: CT8903, CT1745A, CT1972, CT1703."
Reply 3 of 29, by AdamP
Post removed because it was another load of tosh
Reply 4 of 29, by commodorejohn
Okay, thanks.
Reply 5 of 29, by Cloudschatze
AdamP wrote:
According to this, the CT1747 is CQM.
No, it isn't. I'm amazed at how many people still refer to that incorrect post.
"dvwjr" make a number of incorrect assumptions, and never bothered to revisit or edit the misinformation.
Reply 6 of 29, by AdamP
How do you know that? My AWE64 Gold has a CT8903, and I know for a fact all AWE64s have CQM.
Besides, the OPL3 wouldn't have a Creative number, as it's not a Creative chip.
EDIT: I've just had a look at this. It seems you are right in saying the CT1747 is not the CQM. But the question remains: what is it? It seems to be a branded version of an OPL. Or could it perhaps be both OPL3 and CQM, depending on the card?
Reply 7 of 29, by Cloudschatze
All AWE64s do have CQM, as far as I'm aware. You'll notice that I specifically quoted the statement regarding the CT1747 chip.
You'll find that in that same QuestStudios thread, I'd initially assumed that the CT1747 contained an OPL3 core, given the fact that the later CT1747 chips bore Yamaha's trademarked OPL logo. (Earlier chips lack this marking, due to the fact that the trademark/logo didn't then exist.) This, coupled with the fact that the output from both the CT1747 and YMF262 sounds exactly the same, led further credence.
Lastly, I took my own suppositions to Dave Rossum (who both works for Creative, and designed CQM), who not only verified everything supposed, but further revealed that the CT1747 was a joint-venture between Creative and Yamaha (which is why it has a Creative number), and that all such chips were manufactured by Yamaha. Creative had a number of such OEM dealings.
Reply 8 of 29, by AdamP
So technically, the CT1747 isn't the "actual OPL3" the OP wanted?
Reply 9 of 29, by Cloudschatze
The CT1747 has an actual OPL3 core. 😵
Reply 10 of 29, by AdamP
Okay, now that we've established that what I showed the OP was complete tosh 😀, does the CT3670 have OPL3, or CQM? It has the same integrated chip my AWE64 Gold has, and that has CQM. Also, I take it this means that the CT8903 doesn't have CT1747 integrated?
I just hope I haven't misled the OP.
I take everything I said back. It seems you weren't misinformed after all 😀.
Reply 11 of 29, by shspvr
To me the CT1747 look more like the main auido processor chip, it also used on the SB16 CT2290 and other.
So over time everthing get integrated in chip
Reply 12 of 29, by sliderider
Nobody has answered the original question, though, which was what is a CT1745A?
Reply 13 of 29, by Jorpho
I happen to have a CT3670 on hand. Is there some kind of test that would establish the answer to this question?
Reply 14 of 29, by AdamP
Assuming that thread is correct (I now know it probably isn't), it's an analogue mixer.
There was a program floating around (which was available here) that identified the chips in a Sound Blaster card, but it seems to have vanished off the face of the Earth. I'm not sure if it detects the CT1745 though.
5u3 wrote:
Soundblaster 32 PnP (CT3600) […]
220: CT1741 (SB16), FM: CT89xx (CQM), CSP chip: not present
388: CT89xx (CQM)
330: MPU-401 (UART mode only)
620: EMU-8000
If this is correct, it seems that any card with the CT8903 has CQM.
Reply 15 of 29, by Jorpho
I'll go so far as to make a recording of the audio output of a particular program known to sound a particular way on an OPL3, if you like. After all, that would be a far more dependable test than the results of any kind of chip-identifier.
Reply 17 of 29, by leileilol
My favorite is Heretic E1M5. Stupid tune but... it's a good judger.
Reply 18 of 29, by Jorpho
I do have MI2 handy, but is there no convenient command-line player that will get the job done?
It's also been a while, so I have no idea what sort of drivers this thing needs. Will http://www.vogonsdrivers.com/getfile.php?fileid=51 be enough?
Reply 19 of 29, by AdamP
Another game whose music sounds different on different FM synthesisers is Solar Winds. Some tracks sound a bit different on CQM than on ESFM, thought it's been years since I've heard them on OPL3. The closest I've come to that is DOSBox, to which CQM sounds closer than ESFM.
