DOSBox Game Launcher (DOSBox Frontend)
Reply 820 of 2217, by Neville
I have two small requests.
1) Ability to search games and capture data from HOTUD.
2) Search feature. No kidding! My collection is up to 3,000 games now, and sometimes I have trouble locating games. No need for anything complicated, like a result page. Just a simple, browser-like search option would be cool. You know, a small tab to enter the search terms and then the search terms iluminated on the general list. Would that be difficult to implement?
Reply 821 of 2217, by rcblanke
Hi Neville,
1) Would hotud.org be preferred over homeoftheunderdogs.net ?
2) You can use ctrl-f to quickly search on a game title. But I agree that there may be cases where a filter on just the title is too restrictive. Do you think another key combination to create a filter that searches in more attributes (title, notes, publisher, genre, year etc.) would help you?
Reply 822 of 2217, by Neville
1) I wasn't aware of any recent activity at homeoftheunderdogs.net, I have been using hotud.org for ages now. I was meaning the later, anyway.
2) I didn't know of the CTRL+F option. I'm OK with search by title only, but could you make it more visible, by adding a search button or something?
Reply 824 of 2217, by rcblanke
Hi people,
I've just uploaded a new test build, 0.73d, which has:
* Home o/t Underdogs (hotud.org) information querying (Neville)
* Added a brand new Swedish translation from Martin Gustafsson
* Fixed a possible crash-bug when multi-editing profiles (regression since 0.73a)
* Updated some libraries (commons-lang and junit, added commons-io)
I've decided to not allow capturing of game screenshots from hotud.org because it seems that the images they provide are only available with reduced dimensions. So much smaller in fact, that I consider them unusable.
All the latest files
To upgrade, grab the dbgl.jar as usual plus the new libraries in the lib directory: commons-io-2.1.jar and commons-lang3-3.1.jar.
Regards,
Ronald
Reply 825 of 2217, by Neville
Cool, thanks.
Reply 826 of 2217, by Neville
I need some help configuring "Flight Simulator v1.05" under DBGL. The version I got consists of two self-booting IMG files, FS100.IMG and FS105.IMG, both inside a CD folder. Trying to boot any of them separately or in sequence causes a crash when the game starts.
The game came with a pre-configured DOSBox v0.72 environment. Other than machine=cga, cycles=500 and the [autoexec] section I'm quoting, I didn't notice any changes to the DOSBOX.CONF file.
[autoexec] # Lines in this section will be run at startup. @echo off mount C C #imgmount D "CD\" -t iso C: cls echo. echo. echo […]
[autoexec]
@echo off
mount C C
C:
cls
echo.
echo.
echo Microsoft Flight Simulator (v1.05)
echo.
echo PC Booter version
echo.
echo.
echo.
echo.
echo.
pause
BOOT CD/FS105.IMG
#exit
Any ideas on how can I run this game under DBGL?
Reply 827 of 2217, by Qbix
Rank DOSBox Author
DOSBox Author
the game needs and old version of dosbox, because of exceptions with division are handled.
Water flows down the stream
Reply 828 of 2217, by Neville
There's a patch in Peter Ferrie's website, but I don't know if it helps in this case.
Reply 829 of 2217, by telanus
for Flightsim 1.00 and 1.05 I use MESS.
Reply 830 of 2217, by rcblanke
Using ripsaw's fix it's seems to work somewhat in DOSBox 0.74. Not a DBGL issue though.
Reply 831 of 2217, by leileilol
I haven't been following DBGL in a while
There's this bug in v0.73 where I used to have a default profile/dosbox with mount points left in by accident at the autoexec, I cleared them out
And it still is retained every time I edit a profile? This is bad when I have mass-edited profiles to switch dosbox build and so. Now I have the wrong mount c's in every profile!
Any plan/way to mass edit them all out? I didn't backup my profiles folder 🙁
Debian's fucked
Reply 832 of 2217, by SKARDAVNELNATE
I find it's easier to have 2 instances of DOSBox in the versions tab. The original DOSBox 0.74 and a copy that I named DOSBox 0.740.
DOSBox 0.74 is the one that's used with game profiles so I leave the conf untouched.
DOSBox 0.740 is the one I edit as needed when installing a game or testing different settings.
Reply 833 of 2217, by kolano
You can select multiple entries and then select edit. Changing settings in that mode will update all your profiles.
Reply 834 of 2217, by leileilol
You can't edit mount points that way
Debian's fucked
Reply 835 of 2217, by kolano
Ah sorry, I'd forgotten that.
An alternative would be to Grep search-n-replace within your profiles folder...
http://www.wingrep.com
Reply 836 of 2217, by anony
sorry if this is obvious but is there a way to import my old profiles from version v0.60, which did not have an export feature, to v0.73, or should I re-do the profiles manually? There is a "Migrate Profiles" function in v0.60 but I'm not sure if that's relevant. Thanks.
Reply 837 of 2217, by rcblanke
Hi Anony,
You're talking about DBGL versions 0.60 and 0.73, right? If so, start by making a backup of your DBGL directory. Then, download the DBGL 0.73 zip-file and copy the following files over to your own existing DBGL 0.60 folder:
- /dbgl.jar (overwrite the existing one)
- /launch.exe
- the entire /lib folder (overwrite files if necessary)
- the entire /xsl folder
- the entire /DOSBox-0.74 folder
DBGL should then upgrade your existing profile data automatically on the first startup.
If you also want to upgrade the DOSBox version for your profiles, you will have to add DOSBox 0.74 to your DOSBox versions list. Then, select all profiles, choose 'edit profiles' and pick the newer DOSBox release to which you would like to associate them to.
Reply 838 of 2217, by leileilol
Maybe for my bizarre mounting/default config screwup that resulted in making profile incomplete, you could have a [autoexec backup] section of the [autoexec] section of the profile that gets updated per successful change that doesn't end with CONFLICTING_SETTING, asking to restore if editing the profile warns that it's incomplete?
Debian's fucked
Reply 839 of 2217, by rcblanke
That's one possible way of dealing with this issue, indeed. For the moment, though, I choose to simply display a message whenever the user is multi-editing profiles, then loading a DOSBox version where the dosbox.conf mounts are different for the dosbox.conf that the profiles are using. Dealing with the mounts can be rather awkward in this case, and I have trouble reproducing your exact problem. Thus, I simply show a message box recommending to make a backup of DBGL's profile data if this particular case arises. Maybe - when I'm bored - I'll dive into this problem a bit more, but as I said, the exact solution is not obvious.
I'm afraid you'll have to manually repair your profiles, Lei.
0.73e is up:
* Show warning message when loading a different dosbox version and conflicting base mounts are used (when multiediting)
* added 'About' dialog and rewrote settings dialog a bit to have nested websearchengine tabs
* Made filters more prominent in the main menu
* Updated SWT library to 3.7.2
To upgrade, grab the dbgl.jar as usual.
Regards,
Ronald
