Reply 20 of 29, by Dominus
- DOSBox Moderator
I tried but wasn't much of a help 😉
Hi- There is a new bug when compiling the most recent source. CMake configures and generates fine, as far as I can tell. I now encounter this error, during 'make':
[ 98%] Building CXX object mt32emu_qt/CMakeFiles/mt32emu-qt.dir/src/audiodrv/QtAudioDriver.cpp.o/munt-munt-ae9a535/mt32emu_qt/src/audiodrv/QtAudioDriver.cpp:70:34: error:'estimateActualSampleRate' is a protected member of 'AudioStream'realSampleRate = AudioStream::esti...^/Volumes/Mac_USB_HD/Andy/Downloads/munt-munt-ae9a535/mt32emu_qt/src/audiodrv/AudioDriver.h:17:16: note:declared protected herestatic double estimateActualSampleRate(const double sampleRate, ...^1 error generated.make[2]: *** [mt32emu_qt/CMakeFiles/mt32emu-qt.dir/src/audiodrv/QtAudioDriver.cpp.o] Error 1make[1]: *** [mt32emu_qt/CMakeFiles/mt32emu-qt.dir/all] Error 2make: *** [all] Error 2
Same system as before. Any help would be appreciated. Thank you for all your hard work. 😀
Uh, seems you've found a bug in Xcode 😒 That's a shame...
Okay. Thank you for letting me know where the problem is.
I have found the solution. The problem is with Xcode's version of Clang. Mt32emu-qt compiled once I specified the compilers to /usr/bin/gcc and /usr/bin/g++ in CMake. That should be a temporary solution until/if Apple fixes the bug in its version of Clang.
Funnily as you are on Lion and thus on Xcode 4.2 or 4.3x you don't actually have gcc 😉 those gcc & g++ in usr/bin are just symlinks to lvm-gcc/g++
I've run into something like that too before some time ago. You could send Apple a bug report if you are in thd developer program.
Hmm, that's not too fun in this case 🙁 Well, QtAudio seems anyway useless for Mac, I can just disable it in order not to invent horrible workarounds...
I've tried to compile this in Linux. The cmake step failed because it couldn't find PulseAudio. I deleted that from the CMakeLists.txt.
Aftet that, the build aborted because it couldn't find "asoundlib.h". I've fixed mt32emu_qt/src/audiodrv/AlsaAudioDriver.h to #include <alsa/asoundlib.h> instead.
That worked and I got a binary. I ran it, but when I select "Options->ROM Configuration", it crashes with:
Qt has caught an exception thrown from an event handler. Throwingexceptions from an event handler is not supported in Qt. You mustreimplement QApplication::notify() and catch all exceptions there.terminate called after throwing an instance of 'std::bad_alloc'what(): std::bad_allocAborted
I'm on Qt 4.8.2.
Oh, thanks.
As it reads at http://www.cmake.org/files/v2.8/CMakeChangeLog-2.8.8
Changes in CMake 2.8.8-rc1 (since 2.8.7)
FindALSA: Fix incorrect include path detection
The software world surely evolves 😀
I already use 2.8.8 though. I upgraded to it on Thu May 3 2012 (from the logs.)
