Reply 1 of 10, by Dominus
- DOSBox Moderator
1st, dos4gw seems to be more compatible
2nd since Dosbox doesn't emulate a Voodoo card no wonder it crashes
3rd your caps lock key seems to be broken
Reply 2 of 10, by javilevel
Yes with DOS4GW there isn't any problem ,DOS4GW.EXE ver.2.01 with S2_3DFX.EXE runs good but it's very slow. My problem is why DOS32A crash if with de screamer 65000 colors and hig resolution it's OK, and very fast.
The only problem is trying DOS32A.exe with s2_3dfx.exe.
Reply 3 of 10, by leileilol
- l33t++
If it already works by default with its included dos4gw, then why try dos32a?
Debian's fucked
Reply 4 of 10, by javilevel
The difference is the speed, DOS4GW is very slow.
DOS32A is very fast.
Reply 5 of 10, by Dominus
- DOSBox Moderator
No, it seems the difference is that it works with dos4gw and crashes with dos32a 😉
Reply 6 of 10, by leileilol
- l33t++
I always thought dos32a's speed was a placebo effect
it certainly won't help the performance of any emulated 3dfx.
Debian's fucked
Reply 7 of 10, by Dominus
- DOSBox Moderator
Not to mention that non release versions of Dosbox are generally not supported here. You will have to ask yhkwong directly
Reply 8 of 10, by javilevel
ok, I understand.
Tank you for yor reply.
Reply 9 of 10, by wd
No but the techniques (fast-irq and the likes) are not significant usually.
Don't know for this game though.
Reply 10 of 10, by gulikoza
- Oldbie
dos32a does not support the method of loading glide2x.ovl so it won't work with any 3dfx stuff...
