First post, by dirkmirk
Im giving up on the tualatin project for the moment as the motherboard seems to be faulty, that machine might become a Pentium 4 845 isa system if I get that impulsive feeling again.
However, I am very pleased with this system.
MICRONICS W6-LI - Dual Pentium PRO (Socket 😎
http://stason.org/TULARC/pc/motherboards/M/MI … -Pro-W6-LI.html
Dual pentium pro motherboard, ATX! This came with a very handy and maxed out 512meg of ram
Pentium 2 overdrive 333mhz, the very last overdrive intel produced, nice performance increase over the Pentium pro 200 with 512 full speed cache & mmx.
BFG 6200 OC PCI 256meg, this card is the fasted thing in PCI format if you want to run windows 98, it also has DVI for crystal clear images on a modern LCD, a quick slew of benchmarks in dos showed no funny imperfections.
Soundblaster 32 PNP ISA CT3670(AWE32), This is no AWE64 Gold but close enough, it has a 4.16 dsp which should provide trouble free mpu-401 emulation, FM/OPL music is still very good with excellent sounblaster compatibility.
I ran some benchmarks before I swapped the Pentium pro 200 for the overdrive 333.
I was expecting a bigger increase in Quake 2/3 scores with the cpu upgrade, I knew the CPU would bottleneck the graphics card but I was suprised at how well the old 200 scored.
Fast vid shows a great increase in dos based programmes, definately worthwhile for both pentium pro and pentium 2 machines.
I'll update the thread soon with more pictures, these are the specs, obviously the idea was to make a machine as powerful as it can be.
MICRONICS COMPUTERS W6-LI (Socket 😎
Pentium 2 Overdrive 333
512meg EDO ram
Sounblaster 32 PNP ISA CT 3670
Sony CD Burner
1.44 Floppy
High UDMA 66 PCI ide controller
Maxtor 80G hard disk ATA 133
[/url]
