First post, by Gamecollector
Need the correct gpl12_uk.exe. Papyrus and Sierra sites are long dead. All links to this file are dead or - the result is broken archive (crc 4057e30f). Plus the file is 1 byte shorter.
P.S. i CAN run mu copy of Grand Prix Legends UK if I use "all-in-one 2.3" patch. But I am preferring to add the patches separately...
Tnx.
Reply 2 of 6, by Gamecollector
No. I need the .exe. My GPL cd wasn't working with this .zip patch and I suspect the .zip just contains an files from the broken .exe.
Reply 3 of 6, by Procyon
Patches Scrolls gives me headaches, luckily you can still get it here.
However if you are going to run it on XP or 7 you're likely to run into sound or graphics problems anyway.
For the most troublefree experience I recommend getting the latest installwrapper.
Reply 4 of 6, by Davros
perhaps you need the u.s patch ? that contains a patch exe, gpl12_us.exe
or the u.k patch and the fast cpu patch
why doesnt the zip work for you ?
ps: why do you want to add the patches manually ?
Reply 6 of 6, by Gamecollector
Found the file through web.archive.org.
@Davros - no, my GPL cd is uk. Us patches can't install to this version.
Tested the .exe and .zip, the content is identical... Hmm. Well, negative result is still the result...
Why I need the patched separately? Glide wrapper testing.
Case closed.
    gpl12_uk.exe
    1.26 MiB
    382 downloads
