programming project
First post, by ncmark
If anyone's interested, I have been fooling around with programming in assembly
The first one, written a while back, reads and displays sectors off a floppy disk
The second one, which I have been working on now, reads the FAT and gives you a visual display in hex code - shows you which ones are available, which are assigned, which are bad
The third, also currently working on, reads the root directory and displays the entries (not just the ones DOS wants you to see, but all of them)
I am thinking of combining the second and third programs - once you select a file it follows the chain and gives you a visual display of the sectors used
Reply 1 of 11, by ncmark
AW, there's NO ONE with a comment? No one fooling around with assembly? I learned quite a bit fooling around with this...
Reply 2 of 11, by Joey_sw
i mostly use Norton Utilities' DiskEdit ...
though i'm looking for Directory Compactor for FAT16/32.
whats that?
consider this:
1. create a directory,
2. fill that directory with about 2000 small-files (let say group A),
3. add another 1 file to that directory (let say group B)
4. delete the group A files, but leaves the Group B
5. If you look cluster usages of that directory, its obvious that it using more than 1 cluster.
Under slow system, the performace degradation were quite noticeable.
Directory Compactor that i'm looking for is to optimize the cluster usages of directories to minimum required.
Its done by removing directory entries that marked as deleted, and adjusting the cluster chain in FAT entries.
comparable to PACK command on dbase, somewhat.
You know, most defragmenter doesn't do this 'Directory Compactor', they just leave it as is.
Even Defraggler working under FAT32 partiion doesn't do that.
-fffuuu
Reply 3 of 11, by ncmark
yeah as far as I can tell nothing re-organizes the (root) directory entries - when you delete a a file, all it does is change the first character - the rest of the filename, as well as the starting cluster, are still there. I guess that is why undelete must ask for the first character of the filename.
I haven't got to reading subdirectories yet. I can tell when something is a subdirectory, but to read it I am going to have to switch logical sectors into physical sectors, as I have been using BIOS calls (not DOS calls) to access the disk........
Reply 5 of 11, by ncmark
I think assembly is cool - it is compact, and lightning fast, and if you want to work at the hardware level it's the only way to go 😜
Reply 6 of 11, by badmojo
Lightning fast to execute but sloooooow to write. 😀
Reply 7 of 11, by ncmark
I had become very good at assembly on the commodore 64, but unfortunately by that time the world ad moved on t he PC. And programming the PC is MUCH more complicated....
Reply 8 of 11, by VileR
Been messing around with x86 assembly as of late, trying to learn as I go. For now I'm just using the DOSBox debugger, the 8086 opcode map, and a hex editor to poke around the innards of really old games and see how they like being patched for enhanced / unintended behavior. ;)
Certainly seems to require an intimate knowledge of PC hardware architecture, and coming from higher-level languages, it's far from being trivial. But it's rather rewarding when you get down to the bare metal and achieve unprecedented control of what the machine can do.
Reply 9 of 11, by megatron-uk
The thing is, these days most compilers can generate machine code that is much more efficient than most people could write in assembler 😀
https://www.target-earth.net
Reply 10 of 11, by ncmark
I am not sure I agree with this........
Reply 11 of 11, by Joey_sw
i'm not also unsure about compiler can generate better code than hand writen assembly though.
I can attest that even with -O option to optimize,
more efficient/better code in hand writen assembly can be made,
this especially true if the non-assembly codes using stuff like bloated-OOP (class derivates, polymorphism, even opertator overloading, etc...)
anyway, some proponent assembly for windows apps: http://www.grc.com/smgassembly.htm
-fffuuu
