First post, by tincup
The oldest version of FRAPS I can find is 1.9d, and it doesn't seem to run under W95. Is there an earlier version that does, or another app that will work?
Also I doesn't appear that Fraps works in Glide - is this true?
Reply 2 of 10, by vetz
Only way to capture Glide games is either to run them in a wrapper and then capture with Fraps or buy a VGA capture device.
Reply 4 of 10, by Mau1wurf1977
I also recommend a VGA capture device. These are PCIe cards and quite affordable (though not dirt cheap). A cheaper option are VGA to -S-video converters (lower quality though but often good enough).
My YouTube channel
Reply 5 of 10, by leileilol
Alternatively there's many Voodoo3's with S-video out. Only real problem is their EGA/VGA handling leading to garbled images
Of course, s-video capture quality varies a lot and it only works best at native NTSC 720x480. some 720x480 XL-R8R footage
Reply 6 of 10, by Mau1wurf1977
Very nice!
I have tried heaps of cards with S-Video out (no 3D cards though) and most have issues at certain resolutions or settings. That's the main reason why I use the VGA to S-Video converter. It takes whatever resolution and records it in acceptable quality.
But for specific captures direct S-Video from the cards gives the best quality. PAL cards have higher resolution but lower frame rate.
Reply 9 of 10, by leileilol
I wouldn't bother with old Fraps because of the 30fps max and also the terrible speed of writing to a old FAT12/16/32 drive might be excruciating while playing.
And for the record, Fraps doesn't work on SGL either. 😀
