Reply 20 of 26, by Dominus
 - DOSBox Moderator
Official SVN is at the SF location. You mean an official SVN BUILT! But there is no official one. The one you link seems to be as close as it gets though.
Right OK, many thanks, I promise to stop asking stupid newbie questions now 😀
There is no "official SVN" except the dev sources.
Yes, I realise that now, many thanks
Just thought I'd let anyone that is interested know that I managed to resolve the original error (This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem) by installing MS .Net Framework 2.0 with SP1 also applied. No idea why this worked, but it did! strangely just installing .net 2.0 did not resolve it, it was only resolved after applying the SP1 update.
My System: ASRock P4i65G MB, Win98SE, P4 2.4GHz, 512MB Ram, Nvidia GeForce 4 TI 4600, Sound Blaster Live! 5.1
especially as dosbox doesn't use .NET
Water flows down the stream
wrote:especially as dosbox doesn't use .NET
Yes i know, it's really is paranormal, maybe i should report this to The Fortean Times!!
