warcraft 2
First post, by psiK88
how do i link a DOS game to a desktop icon using DOSBox? i can play the game but i cant seem to link it to an icon. That way i dont have to reactivate dosbox and go through the process again. Any help would be highly appreicated. Thank you.
Reply 1 of 7, by bloodbat
You could probably read the readme and use the -conf parameter after editing the autoexec section of a custom .conf and creating a link to dosbox wherever you want it to load your .conf file...or use command line parameters. You could also try a frontend, I guess.
Reply 2 of 7, by SKARDAVNELNATE
Or use a front end with the option to create a shortcut.
Reply 3 of 7, by psiK88
ok i got the shortcut working but it work read my cd drive. i have the disc in but it tells me to insert the disc. i tried re loading the disc but that doesnt work.
Reply 4 of 7, by bloodbat
I'll assume that what reads
is meant to say "it won't read my cd drive".
You have to mount both a folder to act as hard drive and the CD, use the same mountings you used when you had it working.
Reply 5 of 7, by SKARDAVNELNATE
Post a list of everything you've done including mount commands.
Reply 6 of 7, by psiK88
fyi im not very computer savey
this is the page im using----
http://www.doctort.org/adam/nerd-notes/warcra … step-guide.html
the DOSBox.conf file is what i was told to use with 1 or 2 modifications. the only thing cant seem to do is have the shortcut read my cd drive.
The .conf file is 6 pages long, i can post it if u need me too.[/url]
Reply 7 of 7, by bloodbat
You should post the .conf file...I doubt its 6 pages long (of course that would depend on your page size)...
Anyway these lines are key:
mount c C:\DOSGAMES\
mount d D:\ -t cdrom
If you followed that guide you posted to the letter, those should appear on the autoexec section of your .conf file, probably along with
c:
cd \war2
war2
Of course that would depend on the folder you installed Warcraft 2 to...I'm no longer sure war2 starts warcraft 2, I moved to the battle.net edition a long time ago...so change the folder to the right one and the command, if needed, to the proper one (though the guide you posted agrees with me).
