First post, by lucky7456969
like restore memory, restore interrupt chains etc
So that the dosbox won't slow down after loading heaps of stuff and stop after finishing playing with them and returning to the prompt?
Just a matter of habits, don't want to restart all the times.
Thanks
Jack
Reply 1 of 8, by Jorpho
You really need to be more clear when you write your posts, as I for one have no idea what you are talking about. 😒
How to Ask Questions the Smart Way
Reply 2 of 8, by DosFreak
In MS-DOS you had to reboot quite often because of issues causes by games\programs. He wants the capability in DOSBox where that is not required.
Instead of a developer trying to analyze every possible way for a DOS program to screw things up it would probably be easier to revert DOSBox back to the same state it was when DOSBox was first started.....problem is when would DOSBox know when to do this.....
A Z: drive "reboot" command initiated by the user would likely be the easiest solution.
Make your games work offline
Reply 3 of 8, by ripsaw8080
Rank DOSBox Author
DOSBox Author
SVN already has something like that for restarting: config -r [parameters]
Reply 4 of 8, by Jorpho
Oh. I have to say that is the first time I have ever heard of this. (Short of programs that just completely hung the system, of course. And there were those that screwed up the video mode upon exit, but those were rare.) Is there a specific example that is common?
Reply 5 of 8, by DosFreak
I guess "often" depends on what crazy programs you were running and how many. heh.
I wish I had kept a list but never did....easier just to reboot.
Yup config -r appears to work fine.
Reply 6 of 8, by leileilol
I've had Quake progressively cause segfaults everytime I quit eventually affecitng other parts like sound, particularily version 1.00 (not 1.01), on a real system.
Debian's fucked
Reply 7 of 8, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Not to mention that so many games needed custom autoexec/config that I found myself rebooting often enough to never encounter that...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 8 of 8, by Joey_sw
well, dosbox could pause/unpause leasurely, surely it counts as something that real system can't do ?
-fffuuu
