Reply 20 of 31, by MaxWar
- Oldbie
I practiced ribbon cable crimping on a scrap cable with the vise technique. Good thing it was a scrap cable because I screwed the connector when removing it. Some of the metal pins stayed with the cable and got ripped off the plug 🤣.
I still crimped it back somewhere else and that part went well.
Not sure i want to try to remove the connectors off my 26 pin cable in case i just rip them pins again. The redneck method suddenly seems like not such a bad idea 😁
Or the small PCB technique used by Gerwin seems quite convenient also.
The other thing is that my 26 pins cable is 2 feet long, maybe its a bit too long... The redneck method could solve that at the same time...
Edit : Myself = complete dumbass . I just now took into consideration that my cable if female at both end , *facepalm* Guess ill scavenge some header from a bricked board.
FM sound card comparison on a Grand Scale!!
The Grand OPL3 Comparison Run.
