First post, by Noisia
- Newbie
Hello!
I've tried to install GTA unsuccessfully. I've mounted the ISO using powerISO booted DosBox 0.74, mounted C: and D: drivers accordingly, then perfomed d:\install. The install menu prompts me to install the game to the default directory c:\GTA and then the installation terminates with the following error message:
"Couldn't open Startup.ini"
"Illegal command dino.bat"
I've decided to print the Status window for better understanding:
Am i overlooking configurations or is it somekind of emulation error?
Thanks in advance! 😀
