First post, by dmcc98
Just discovered I can't run it under 64-bit Window 7. So, in my search for a solution (before installing 32-bit Windows 7), I found DOSBox as a possible solution. Does anyone have MYM running successfully in a DOSBox/Win7 environment? If so, what should I know about getting it (MYM, DOSbox or Win7) setup correctly so I can run MYM successfully?
Thanks
