First post, by KarjamP
You do remember that Vista removed the option to change the default midi device from that Microsoft Synthesizer but you get around that by editing the registry itself?
Well, Windows 8 removed that ability.
That's right, tools like "Windows Vista MIDI Picker" won't work on Windows 8!
Therefore, you're stuck with using the crappy synth unless either another workaround is found or the software itself offers the option to change the synth it uses to generate midi.
Too lazy to properly proof read. 😅
