Using USB gamepads
First post, by mgman
Does DOSBox support USB gamepads alright? I have a Logitech-brand gamepad (sorry, can't get into the details ATM as I'm away from it); do I simply calibrate it through Windows and run a game in DOSBox that supports joystick?
Also, how do I check if DOSBox recognizes the gamepad/joystick?
Reply 1 of 3, by bloodbat
Yes, it does.
It should be listed in the status window with axes and such.
Reply 2 of 3, by leileilol
Cycles can also play an important factor into calibration.
Debian's fucked
Reply 3 of 3, by mgman
Hmm.
I just checked that, specifically, my gamepad is a Logitech Dual Action USB Joystick.
Strangely, DOSBox recognized it as a 4axis type of joystick. It didn't work with the games. But changing the joysticktype in conf to 2axis and setting the 4 options below it to false (as was pointed out in a thread I found by google) made it work.
