First post, by subhuman@xgtx
Same as title. Every time I try to launch the gold patch Accelerated installer it does a quick file checking and an error message that says "Verify of new file failed. Possible Internal Error." appears, and If I click ok then it says "Patch was unsuccessful" My rig is a single barton 2800 MP+, 3gb of ddr400 ram(limited to 256 megs atm), 400gb ide hd (WIN98se partition of 180gigs), Quadro 2 pro + Q3D SBi 200 and a sq2500. Could someone tell which could be the reason of this?
Thanks guys
Reply 1 of 4, by filipetolhuizen
Corrupted file maybe? Tried getting it from somewhere else?
Reply 2 of 4, by subhuman@xgtx
It's quite strange because the game is installed properly.. I tried to install-uninstall the game several times thinking this was the reason but nope..
I tried the cds a friend gave me and I also tried to download the two discs from the net
Reply 3 of 4, by leileilol
In the normal game, when it says "SOMEWHERE IN THE SOUTHWEST..."...are there other words on the screen?
Reply 4 of 4, by filipetolhuizen
Actually I was talking about the patch installer. Have you tried downloading from somewhere else?
