First post, by silikone
I have one of these lying around, but I can't find the adapter to power the motors. The only reserve adapter with an appropriate DC output I have does not fit into the port.
Does anybody know what kind of plug it needs? Are replacements easy to find?
Do not refrain from refusing to stop hindering yourself from the opposite of watching nothing other than that which is by no means porn.
Reply 1 of 4, by mr_bigmouth_502
Find a spare power adapter with a plug that fits, even if it's not the correct voltage, then cut it off and splice it onto the power adapter with the correct voltage. I actually had to do that the other day to get an old pair of computer speakers working. 🤣
Reply 2 of 4, by silikone
I haven't even found one suitable plug. Many can reach deep without being tightened, but I don't know if a connection is made. I've searched on Google, and it looks like a common laptop plug on images, though I can't tell for sure.
Reply 3 of 4, by rug
You should pay attention to the voltage, current and polarity.
Then, a universal power supply should solve your problem.
Cheers,
Rita Graça.
My DOS machine: MS-DOS 6.22, Pentium MMX 200MHz, 64MB RAM, AWE64 Gold, 4GB HD, Philips 19" CRT, 3"1/2 Floppy, CDROM, Parallel ZIP, ThrustMaster FLCS+TQL+Elite.
Reply 4 of 4, by pinkdonut666
it's a 24volt supply, and is like 2 amps, so just make sure if you do use a multi supply it can handle that.
my life runs on X86
