First post, by MusicallyInspired
Is there anything I can do? I was so sure that I got the perfect laptop, but I discovered (too later after owning it for months) that it lacks firewire and I have a fairly needful use for it. I understand that USB to Firewire is impossible. What about USB3 being faster? My laptop also does not have an expresscard or PCMCIA slot. Is there such thing as an ethernet to firewire adapter? Am I out of luck?
Reply 1 of 17, by Old Thrashbarg
You're pretty much SOL. The only realistic way I'm aware of to add firewire to a laptop is by PCMCIA or Expresscard.
There are some miniPCIe firewire cards available, but they're not really practical for use in laptops for various reasons, and they're also quite pricey.
Reply 2 of 17, by TheMAN
what "perfect" laptop is this?
Reply 3 of 17, by collector
http://www.amazon.com/IEEE-1394-FireWire-Fema … r/dp/B007DNHQPE
Don't know anything about it, but the USB speed would be a bottleneck, but at least you might still be able to use some firewire devices with the laptop.
The Sierra Help Pages -- New Sierra Game Installers -- Sierra Game Patches -- New Non-Sierra Game Installers
Reply 4 of 17, by Old Thrashbarg
That adapter isn't going to work... firewire can't be converted to USB that easily. I don't know why they even make such a thing, I can only guess that it must be for some specific non-standard sort of device that will put out USB signals on the firewire port.
Reply 5 of 17, by Jorpho
They're making laptops without PCMCIA now? When did that start happening?
Reply 6 of 17, by SquallStrife
Or maybe there's a little bridge chip buried in there... OR, it's just for charging old iPods from USB ports.
Reply 7 of 17, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
If you read the reviews on this item you will learn that it does nothing 😉
You will need another machine with firewire...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 8 of 17, by Old Thrashbarg
Definite no on both counts. Even if a firewire->USB bridge chip did exist, it is highly unlikely that the necessary circuitry would fit inside a little plug adapter, and it would certainly cost more than $2.
Nor is such an adapter useful for charging iPods, or any other firewire device, since firewire works on an entirely different voltage and current capacity.
Reply 9 of 17, by Leolo
Yes, you're out of luck.
I've seen a similar case with a friend of mine who recently bought a super-expensive 15" Macbook pro Retina, hoping that he could still use his older (but hugely expensive in its day) SCSI flatbed scanner.
He's out of luck also. There used to be a time when external SCSI controllers were available in the market, but now they are horribly difficult to find (and even if you could buy them second hand, there would probably be no drivers for newer Mac OS X versions).
He has to keep an older computer which was upgraded with a PCI SCSI card just to be able to use the scanner.
Reply 11 of 17, by MusicallyInspired
Good to know. My laptop is the Asus N53SN. I love everything about it. Except its lack of Firewire. Guess I should have been more observant, even more than I was. Though, I gather that fewer and fewer new laptops are made with Firewire nowadays anyway. I wanted to use it to control and record from a PreSonus StudioLive 24x4x2 mixing console. Ah well. Thanks for the info.
MuntVSTi Editor
FB-01 tools
Github
SC-55 Packs
Reply 12 of 17, by swaaye
PCMCIA/Cardbus went away years ago when Express Card came along but that seems uncommon too. I suppose everything tries to be USB now even if PCIe would be much better.
Reply 13 of 17, by TheMAN
frankly, that is what you get for buying a consumer grade laptop... you limit yourself in durability, reliability, configurability, legacy peripheral support, and expandability
the usage requirements you demand are usually found on business grade laptops these days...
can't afford a new one? buy an off lease one!
need warranty/worried about reliability? get a service contract!
Reply 14 of 17, by SquallStrife
The latest batch of Core i5 based Dell Latitudes they bought at work, have only USB, HDMI, Ethernet and Power connectors.
Consumer or business, I think everything that isn't a behemoth desktop-replacement class of portable is going that direction.
Reply 15 of 17, by swaaye
The primary reason is probably the gradual cheapening of notebooks. Corners need to be cut. And since USB covers almost every peripheral need, Expresscard slots are very low priority. Internal FireWire would seem to me to be more useful because of its use for digital video. But I admit I don't know if it's that critical there anymore.
USB3 is glorious though. Glad that's happening.
Reply 16 of 17, by TheMAN
yet, you can get an expresscard that will solve that problem 😉
Reply 17 of 17, by SquallStrife
Some of the smaller/slimmer ones don't even have that!
Granted, the most common model we bought does have ExpressCard slots this time around, now that USB 3 and Thunderbolt are on the table (and remember that Thunderbolt is PCI Express x1 under the hood), I think ExpressCard will be next IO option to disappear en masse.
