PS/2 on AT motherboard
First post, by duke_nuked_em
I've got a socket 7 motherboard with only the din AT keyboard port built in. What would you suggest for hooking up a keyboard and mouse (I have usb devices, and usb to ps/2 converters). For what it's worth this machine also has 40mb ram, and 120mhz pentium.
I'd considered buying a ps/2 card, but the cheaper ones I saw were new PCI ones with usb built in (a plus) but they said they needed 98 or newer, since this will be a dos/win 95 box I don't know how much hassle it will be to get it to work.
I haven't bought a soundcard yet, but the ISA Soundblasters I'm looking at will have a DB9 port (I'd planned to use that for a joystick tho)
What did people do in the mid 90s? Thanks
Reply 1 of 14, by luckybob
A socket 7 board will have a ps/2 mouse port as well. In fact most have usb.
Take a good picture of the board. or give us a model number. myself or someone else should be able to point out where to plug things in.
Reply 2 of 14, by Joey_sw
and, asuming your USB keyboard & mice were works on system with ps/2 ports, using the converters (since i know some were not),
adding this one probably works.
-fffuuu
Reply 4 of 14, by fillosaurus
Guess it's an Intel 430FX, since it does not have USB. Newer chipsets like 430HX, VX, TX already have USB ports, and in case of VX and TX, SDRAM support.
Considering PCI PS/2+USB cards, they do not need any kind of drivers for the PS/2 ports. Just for the USB, I think.
Y2K box: AMD Athlon K75 (second generation slot A)@700, ASUS K7M motherboard, 256 MB SDRAM, ATI Radeon 7500+2xVoodoo2 in SLI, SB Live! 5.1, VIA USB 2.0 PCI card, 40 GB Seagate HDD.
WIP: external midi module based on NEC wavetable (Yamaha clone)
Reply 5 of 14, by nforce4max
You need to get an adapter for serial if it is FX and it is AT form factor. Only ATX oem FX boards had ps/2 support.
Reply 7 of 14, by fillosaurus
You do not need one of those PCI RS232 adapters. Any socket 7 mobo already has them. If is AT, it has headers. If is ATX, it has'em on the back panel.
I still think a PS2-USB combo card is a good idea. I think I will order one.
Reply 8 of 14, by duke_nuked_em
Thanks filosaurus, it's an AT board so it has the headers. So how do I hook the headers up (like where can I buy one, haven't seen them on eBay). I might go with the usb + ps/2 card tho.
Reply 10 of 14, by Old Thrashbarg
They're not as good an idea as they appear to be. Those things don't actually have real PS/2 ports on them. They use a USB->PS/2 bridge, same as the converter dongles (like these), except that it's mounted on a card instead of a cable. Which means that it won't work for low-level stuff (like getting into the BIOS) on older boards that don't have native USB support.
Reply 11 of 14, by Jorpho
Wouldn't that be a DA-15 port?
http://en.wikipedia.org/wiki/Game_port
Reply 12 of 14, by pinkdonut666
My socket 7 system doesn't have PS/2 or USB. But to be fair it's probably the cheapest motherboard intel made that could fit a pentium. I just use an old AT keyboard and a serial mouse. works fine for me.
my life runs on X86
Reply 13 of 14, by feipoa
It would probably best to just use a PCI USB card and a USB mouse for these Sytems. If you plan to run winnt, I find the 3rd party USB HID mouse driver to work fine, even on a 486.
Reply 14 of 14, by Pilotgeek
If you're any good at soldering, you could see if the board has solder points for a mini-din connector. On my 486-PIO3, I removed the old AT connector and soldered the mouse and keyboard mini-din connectors in place. Everything was in place for the hardware to work (didn't need any resistors or anything).
