First post, by Jorpho
I quite desperately want to pare down some of my surplus equipment. Sitting before me is a Red Fox AGP-ALI Super Socket 7 motherboard, currently loaded with a K6-2/500 and 64 MB of RAM. I think my original fascination with it when I picked it up was that I could toss in an ancient Pentium to slow it down. It also has three ISA slots, which I guess is nice?
The reason I don't think I need it anymore is that I also have an ASUS P3BF with a P3-450 and 512 MB of RAM, which is presumably much faster than the K6-2 and can be slowed down quite nicely by disabling the onboard cache, right? It only has one ISA slot, but I can't imagine why I would need more than one.
So, is there any good reason to hold on to this AGP-ALI? (There are a couple on eBay right now with starting prices of $190, which sure would be mighty nice, but I don't think I could feasibly get that much.)
Reply 1 of 2, by d1stortion
Disabling L1+L2 cache will lead to sub-386 performance on a ~1GHz P3 (there are threads on here where this was tested iirc), so the usefulness of that depends a lot on what you want to play.
The oldest game I've tried with such a configuration was Wolf3d and that was a pain, but for even older games it might be ok. It's certainly not as flexible as a SS7 machine, but fortunately a lot of later DOS games are fine with P2s/P3s or even benefit from them in high resolutions. There are exceptions where it won't hurt to have such a machine if you're in lack of a real 486 though.
Reply 2 of 2, by nforce4max
Disable the L1 but leave the L2 enabled and you will get 486 level performance. With both disabled you will get 386 (slow 386) performance but it homing in on a particular level can take some practice.
