Quake III Timedemo
First post, by feipoa
How do you run the Quake III Areana timedemo? This is a pretty common question asked in many forums but I can't seem to get it working. It seems you are supposed to type this in the console:
timedemo 1
demo demo001
but the system just repeats back to me,
UnnamedPlayer: timedemo1
UnnamedPlayer: demo001
When loading the game, I select Q3DM0, then "I CAN WIN". I have the resolution set at 1280x1024. If it matters, I am using Quake III Arena in NT4 sp6. I installed point release 1.32. Thanks!
EDIT: It seems you need to enter the console before you go into the game. Press ~ at the game startup menu. Now when I type the above, it says it cannot open Demos/demo001.dm_68. Where do you find these?
Reply 1 of 7, by SquallStrife
Those don't seem like the right commands, let me fire it up and check.
Edit: OK, commands are:
\timedemo 1
\demo four
The leading backslash makes it a command instead of a chat message.
I think demo001 related to the shareware version or something? "four" is what's generally used.
Edit2: Also, it will insert the backslash if you hit tab to autocomplete the commands themselves (e.g. timed[TAB] will autocomplete to \timedemo)
Reply 2 of 7, by feipoa
SquallStrife wrote:
\timedemo 1
\demo four
Yep, that did it!
What is a decent framerate for a K6-III-450 at 1280x1024 (non-3dfx)? I get 33.0 fps. This is about what I got in Quake II at 640x480. Why does Q3 seem so fast?
Is there any way to put Quake 3 it into software mode?
Reply 3 of 7, by mwdmeyer
No software mode for Quake 3 only OpenGL.
I get about 35fps on a K6-3-400 with a Voodoo 2.
Pretty sure that it uses 3dnow, which helps a lot.
Reply 4 of 7, by F2bnp
The latest patch only includes Demo004 (I think it deletes Demo001 and Demo002 for whatever reason). Make sure to also type these before you run a timedemo:
s_initsound 0
snd_restart
disconnect
Reply 5 of 7, by noshutdown
why not just choose and play demo from the game's main menu(after setting timedemo 1)?
and i invite you to test my demo in this thread:
introducing my quake3 benchmark demo
Reply 6 of 7, by noshutdown
feipoa wrote:
Yep, that did it! […]
SquallStrife wrote:
\timedemo 1
\demo four
Yep, that did it!
i guess you havn't set quake3 to high image quality, and your quake2 score is a crusher demo rather than a simple "demo01" demo.
Reply 7 of 7, by leileilol
r_allowSoftwareGL 1, then go disable directdraw acceleration. Then, watch your framerate plummet to 4spf 😀
Q3A usually goes around 30fps in busy scenes on a Pentium II 300, so a K6-2 450 scoring in that area should be normal. I squeezed 37fps out of a PCX2.
