First post, by noshutdown
all using 50fsb
pentium has a minimum multiplier of 1.5x, so its pr75, which is used for reference.
k6-2/3 series have a minimum multiplier of 2.5x so they are out of consideration. k6-3 multiplier can be set to 2x using software and get 100mhz, but is still in no way slower than reference.
k6 also has minimum multiplier of 2x, and i would rate it on par with pr75 reference.
k5 has low clock and few multiplier settings: 1.5x, 1.75x and 2x, i dunno if there are other hidden settings. if 1.5x is minimum then k5-75 is just slightly slower than reference and i would rate it pr66.
now for the slowest clock-to-clockers: idt c6 and cyrix 6x86, they both appears to support only integer multipliers, and i dont have plenty of info on how they behave.
idt c6: the slowest clock to clock, if 2x is minimum then its 100mhz and i would rate it pr50, slower than the k5-75.
cyrix 6x86: this may be the deciding factor. its a bit faster than idt c6 clock-to-clock, but rumored to run at 1x when jumpers are 2.5x (i have no info on this). if this true then its the only cpu than run 1x on socket7, and i would rate it pr30.
conclusion:
if 6x86 can run at 1x then its the "winner"
else, if k5 has hidden multipliers lower than 1.5x then it wins.
or else, idt c6 wins.
