First post, by Pawper
- Newbie
Could it be an issue with my system being 64 bit?
My system is 64bit Windows 7 and that seems ok. If you are using the FMV pack then it could be a problem with the codec installation. What exactly do you see when it crashes?
Around 3/4 of my screen is white and there's a pop-up saying "Glidos MFC Application has stopped working."
Here's a replacement exe file. Substitute it for the one in C:\Program Files\Glidos (or whereever you've installed it). Then run in windowed mode, and it may tell us where the crash is occurring.
OK, this time it didn't crash, but was still misbehaving. First bug is that after each FMV it would make a new window in the lower right of the screen. Second is that it seems to be pressing buttons within the game or something. The menu was spinning around and Lara kept backing up once I got in game. Also there was the spinning Glidos logo, huge and in the middle of the screen, although I believe that's supposed to be there?
Alright, I tried it fullscreen, and received this error: http://pbrd.co/Vm6EPW
OK, so I played in Windowed mode without my controller plugged in and I didn't get the backing up in-game.
Need this stuff below?
Starting Glide Server v1.52 (c) Paul Gardiner 2001-2013
VESA mode 0x101
VESA mode 0x101
Open core.avi
Open core.avi
Play FMV
WinClose
VESA mode 0x110
VESA cmd 4F07, 0, 0, 0
Open escape.avi
Open escape.avi
Play FMV
WinClose
VESA mode 0x110
Open cafe.avi
Open cafe.avi
Play FMV
WinClose
VESA mode 0x110
VESA mode 0x101
Resolution = 640x480
Refresh rate = 60Hz
Color format = ARGB
Number of color buffers = 2
Number of aux buffers = 1
Refresh rate = 60Hz
Color format = ARGB
Refresh rate = 60Hz
Color format = ARGB
WinClose
Open mansion.avi
Open mansion.avi
Play FMV
WinClose
VESA mode 0x110
Refresh rate = 60Hz
Color format = ARGB
Refresh rate = 60Hz
Color format = ARGB
GlideShutdown
Firstly the window jumping to the bottom right can be fixed by moving the Glidos dialog to where you want the top left.
Your text cut from the Glidos main dialog confuses me: that seems to suggest several successfully played FMVs. Is it sometimes crashing, sometimes not?
Also, does it always give the same call sequence when it crashes? And is it only if the FMV pack is enabled?
The text cut was from the third go I had at it, in the windowed mode. Windowed mode plays fine. I disabled the FMV pack and received the error popup box (same one as in screenshot linked above) immediately upon running the game, instead of after the opening FMVs. Unfortunately when Glidos crashes the main dialog's log is lost...
Ok. I didn't take enough notice of the title. So the problem is that Glidos wont work in full-screen mode. Use of the FMV pack, just delays the problem because it avoids using Glidos to render the FMV.
I'm still confuse though. Here's the thing: Glidos doesn't call grDrawPlanarPolygonVertexList. I guess the stack tracing isn't working quite correctly. I'd be interested to know if you repeatedly get the same stack trace, and whether it changes when you reenable the FMV pack.
Another thing you could try is swapping to OpenGL rendering, although you'll need Graphics Drivers from your card manufacturer's web site, rather than from Microsoft, for that to work.
OK, I'll give that OpenGL thing a try tonight, when someone more technically proficient than myself is home 😜
I didn't think of asking before, but do you have "Inhibit mode change" checked? Someone else was experiencing the same problem as you and cured it by checking that setting.
OK, my problems now are limited to the huge spinning logo in the middle of the screen while playing. It's no longer on the menu screen, just when playing a level, and the textures of it are wonky.
Ah right. That's there to nag you into registering. That disappears when you register and unlock.
🤣, quite a big nag. I was under the impression that it was supposed to be in the corner of the screen. Alright, I'll go ahead and do that then.
One more thing: Does Glidos have anything to do with controller support? Controls get possessed when I have my Afterglow 360 controller plugged in
Sort of. You are probably using Glidos with DOSBox as the DOS emulation, and DOSBox would be interacting with controllers. You may be able to sort it out by adding lines to Glidos\DOSBox\dosbox-0.73.conf, but I'm afraid I don't know what you need to add. There may be help on this forum somewhere.
