Updated! 😁
Sub 10s
Core i7 3820 @ 4.3ghz, DDR3 2133mhz - 8.752s
Core i7 3930K @ 4.3GHz DDR3 1600 - 8.799s
Sub 15s
Core i5 3470S @ stock speed - 10.312s
Core i7-2600 @ 3.4ghz - 10.867s
core i7 950 @ 3.83GHz: 10.873s
Core i7 3610QM @ 3.3ghz: 11.482s
Core 2 Duo E8400 Wolfdale @ 3.8GHz , MSI P7N SLI Platinum, 2x2GB Corsair XMS2 PC2-6400, Windows 7 x64 Ultimate SP1 - 12.438s
Core2Duo E8500 @ 3.8GHZ (400FSB) - 12.476s
C2D E8500 @3,8 GHz, DDR2-800 4-4-4-12 2T- 12.558s
Core i5 760 - 12.667s.
Core i7-2720QM 2.2Ghz - 12.854s
Core2Duo E8400 @ 3.6GHz (400 x 9) DDR2-800 4-4-4-12 - 12.9s
Sub 30s
e7400 @ 3.33g(333*10), p965,ddr2-667 4-4-4-12 15.6s
Q6600 @ 3.2ghz - 15.953s
X4 960T 4.4GHz - 16.286s
PII X4 955 4.2 GHz, NB 2.6GHz; GA-970A-UD3; 8GB DDR3-1333; XP SP3 32-bit - 16.344s
Intel Pentium Dual Core E5200 @ 3333MHz (266x12.5)- 16.7356s
Phenom II 960T X6 @ 4.1GHz - 16.973s
Pentium E5200 @ 3.33GHz (266 x 12.5) DDR2-533 3-3-3-9 - 17.3s
i3-2330m 2.2 GHz; 6GB DDR3-1333; 7 SP1 64-bit - 17.582s
3.5GHz Phenom II X4 - 19.703s
Phenom II X4 965 3.4GHz - 20.686s
Phenom II X6 1055T - 21.154s
Phenom II X6 1090T -21.434s
Core i3 M330 2.13GHz - 21.513s
Phenom II 3.2Ghz - 21.699s
X4 960T 3.0GHz - 23.353s
Celeron E3400 2.60Ghz: 24.321s
e2160 @ 2.4g(266*9), p965, ddr2-533 3-3-3-9: 25s
Athlon II X3 450 - 25.672s
Sub 60s
Athlon64 3500+(venice)@2.5g(250*10), nforce3, ddr500: 34.5s
Athlon X2 4850e (2.5GHz Brisbane, 2x512k L2) - 36.219s
Pentium 4 (Cedar Mill) 3.75Gz - 36.738s
Athlon 64 3000+ (Venice E6) @ 2.5ghz - 37.172s
Prescott 3.0E @ 3.6Ghz - 38.750s
AMD Athlon 64 X2 4400+ (2.3GHz Brisbane 65nm 2x512k L2) = 39.204s
P4 651 D0 (Cedar Mill 3.4GHz) - 39.750s
P4 3.2C @ 3.6GHz (northwood) - 41.125s
Phenom II X3 E840 (1.9GHz, Caspian core, 3x512kb L2 Cache) = 41.169s
Celeron E1200 - 41.496s
Athlon 64 3200+ 2.2Ghz - 42.594s
Pentium D 930 - 42.844s
Athlon 64 3500+ 2.2Ghz - 43.906s
P4 530J, DDR2-533 4-4-4-12: 44.797s
Athlon 64 3200+ 2.2Ghz - 45.015s
Prescott 3.0E @ 3ghz - 45.094s
AMD Athlon 64 3700+ (2.2GHz 1MB L2, San Diego) = 45.312s
P4 Northwood HT 3.2Ghz - 46.734s
AMD Sempron LE-1100 - 47.750s
P4 Northwood HT 3.2GHz - 48.984s
Pentium D 940 @ 3.2ghz - 50.937s
Northwood 2.8B @ 3.15ghz - 55.57s
Pentium 4 HT Northwood 2.6GHz - 56.578s
Athlon XP 3200+ (2.2Ghz) - 57.406s
Athlon XP 2600+ (2083MHz T-bred 166MHz FSB)- 58.359s
Athlon XP 2400+ (2.0GHz T-bred) - 59.946s
Sub 3mins
Sempron 2600+ (1.83Ghz 333fsb) - 1m 05.438s
XP 2000+ (1.67Ghz Palomino 133fsb) - 1m 23.850s
p3-s 1.4g, 815e mainboard, sdram 2-2-2-5 1:36.5s
Pentium III 1.4S @ 1.6ghz: 1m 38.079s
PIII Tualatin 1400S/512/133 @ 1470MHz / 140FSB: 1m 42.387s
Pentium 3 1400S - 1m 50.764s
Athlon Thunderbird 1400C - 2m 0.766s
Pentium III 1400Mhz - 2m 6.150s
PIII Coppermine @ 1127MHz, PC133 @ 150FSB - 2m 11.278s
1.0GHz Pentium III Coppermine - 2m 21.344s
Slot 1 P3 1GHz FSB100 - 2m 28.654s
Slot 2 P3 Xeon 784MHz (7.0 x 112) - 2m 39.344s
1.1Ghz Celeron Coppermine - 2m 42.641s
2 x P3 800 - 02m 42.750s
P3 Xeon 840MHz (7.5 x 112MHz) - 2m 46.187s
Slot A Athlon 1GHz Orion - 2m 52.087s
Dual Pentium 3 Xeon 700/1Mb SL49P, ASUS XG-DLS: 2m 53.687s
PIII 900; CUBX-E; 512MB PC100 SDRAM; 98 SE - 2m 57.050s
PIII Coppermine @ 966mhz - 2m 57.883s
Slot A Athlon 950MHz Orion - 2m 58.426s
Coppermine 1000 - 2m 58.616s
Sub 5mins
Mobile Pentium 3 650 (Win2000 SP4) - 3m 02.853s
Pentium 3 650MHz - 3m 7.930s
Pentium III 933Mhz - 3m 9.189s
P3 800 Slot 1 - 03m 13.706s
P3 Xeon 750MHz (7.5 x 100MHz) - 3m 14.140s
Intel Celeron 800MHz - 3m 29.461s
Slot A Athlon 600MHz Pluto - 3m 32.616s
Dual Pentium 3 Xeon 550/1Mb SL3CE, ASUS XG-DLS - 3m 34.328s
AMD Athlon 700MHz - 3m 38.915s
Dual Pentium 3 Xeon 550/1Mb SL3CE, Intel MS440GX - 3m 48.672s
Slot 1 P3 550MHz Katmai - 3m 54.808s
Mobile Celeron 500MHz (Win2000 SP4) - 4m 6.975s
Pentium III Coppermine 600Mhz - 4m 7.143s
Intel Celeron 800 - 4m 07.752s
AMD Athlon 550MHz - 4m 13.074s
K6-III+/500 @ 600MHz (6x100) 2-2-2-5 - 4m 52.073s
Sub 10mins
Intel Celeron 466MHz - 5m 03.346s
k6-2+ @ 550(100*5.5), mvp3 board with 2mb cache, cl2-2-2-5 - 5:19
k6-2+ @ 630(105*6), ali5 board with cache disabled, cl2-2-2-5 - 5:26
k6-2+ @ 578(105*5.5), ali5 board with cache disabled, cl2-2-2-5 - 5:29
Pentium II 350MHz @ 5m 29.354s
k6-2+ @ 550, ali5 board with 512kb cache, cl2-2-2-5 - 5:41
Pentium III Katmai 450mhz- 5m 44s
k6-2+ @ 550, ali5 board with cache disabled, cl2-2-2-5 - 5:44
k6-3 @ 450, ali5 board with cache disabled, cl2-2-2-5 - 6:00
Mobile Celeron 500MHz (Coppermine, Skt 495) = 6m 00.120s
k6-3 @ 450, ali5 board with 512kb cache, sdram timing not optimized - 6:07
k6-3 @ 450, ali5 board with cache disabled, sdram timing not optimized - 6:13
k6/3 450 - 6m 18.131s
Pentium II-400 PC-100 CAS2: 6m 20.434s
Pentium II-400 PC-100 cas3 - 6m 27s
k6-2+ @ 550 (100*5.5), mvp3 board with cache disabled, cl2-2-2-5 - 6:36
Celeron 366MHz - 6m 38.563s
k6-2+ @ 450, ali5 board with cache disabled, cl2-2-2-5 - 6:50
Celeron 333MHz - 6m 57.971s
Pentium 2 266MHz - 7m 26.852s
AMD K6-2 @ 495mhz - 8m 7.024s
Celeron 266MHz - 9m 14.117
Pentium Pro 200MHz 256K Cache - 9m 41.396s
K6-2/500 @ 550MHz (half the ram not cached) - 9m 43.870s
K6-2/533 @ 522,5MHz (5.5x95) cl3 XP SP3 - 9m 51.100s
Sub 20mins
Pentium MMX 166 @ 237,5MHz (2.5x95MHz) cl3 XP SP3 - 10m 1.835s
Cyrix MII 300Mhz - 11m 23.560s
Pentium 233MMX @262Mhz (75x3.5): 12m 5.075s
Mobile Pentium MMX 233MHz (Tillamook on MMC-1) - 12m 24.011s
Pentium Pro 200Mhz - 12m 29.815s
AMD K6-233 - 12m 42.204s
Pentium 133mhz - 16m 23.153s
K6-2 475Mhz - 16m 33.135s
k6-2+ @ 133(66*2), ali5 board with 512kb cache, cl2-2-2-5 - 17:30
Sub 30mins
cyrix 6x86 @ 133(66*2), mvp3 board with 2mb cache, cl2-2-2-5 - 20m 55s
IDT Winchip C6 200: 23m 32.450s
Mobile Pentium 120MHz, NT 3.51 SP5- 25m 57.289s
Mobile Pentium 120MHz, Windows 3.11 - 27m 30s
Sub 60mins
Mobile Pentium 120MHz, Windows 98- 30m 23.536s
Pentium 66 - 30min 36sec 231ms
cyrix 6x86 @ 66(66*1), mvp3 board with cache disabled, cl3-3-3-6 - 41m 10s
Intel Pentium 75MHz - 45m 27.274s
AMD Enhanced Am486DX4 120MHz - 50m 31.356s
Sub 30 days
386SX-16 - 27days 19h 31min 43sec
