Time date?
First post, by Cschneider
How do you get date and time to work in dosbox?
I tried the standard date time commands, but i get illegal command..
Reply 1 of 4, by IIGS_User
I think in Z: is a list of legal commands.
Klimawandel.
Reply 2 of 4, by bloodbat
They aren't there, which game uses them?...If for some perverse reason you really want to use them to play a game, you can use 4DOS.
Dir, for example, is an internal command, so it isn't found in z:.[/quote]
Reply 4 of 4, by Zorbid
On this topic, you should know that DOSBox's handling of dates is intentionally crippled. The day is not incremented at midnight.
Not sure if booting a DOS image solves this.
