First post, by PowerPie5000
- Oldbie
I received a Procomp G111 Voodoo 2 card earlier today (12MB version) and it keeps freezing every time i try to access the Voodoo display properties or even run DXdiag! I've tried swapping PCI slots and reinstalled the drivers (after using a driver sweeper) and nothing seems to work!
Has anyone else had problems like this? I'm running it with a PIII 850, i440BX board and a Geforce 4 MX440. I even swapped out the PSU but it made no difference 🙁. I wonder if it just doesn't like the GF4 MX440? I've had a pair of STB V2s in SLI with this machine before and it worked fine (linked to an ATI Rage Fury Maxx). I even reinstalled DirectX and reset the config data in the bios.
Anyone have any suggestions as to what it might be? There are no reported device conflicts either 😒.
