Games that don't run properly on faster CPUs
First post, by d1stortion
I thought of creating this article in the wiki, but I need some suggestions, since I don't know too many so far. I know a lot of/most old CGA games need a 8088 4.77 MHz, but I'm talking newer than that, because since the 386 era, most games seem to play right on much faster CPUs than what was common at their release. Therefore, I'd like to limit it to roughly 1990+ for the most part.
Only original releases, no source ports. If a game has patches which enable it to run with faster CPUs it should be noted. The ones that I know of are Descent (runs too fast), Descent 2 (mouse sensitivity bug on high framerates) and for Windows games Wipeout XL aka 2097 (supposedly has a patch which fixes it though). Jazz Jackrabbit needs the TPPATCH utility and runs fine with that.
Wiki article: http://www.vogonswiki.com/index.php/List_of_C … sensitive_games
Reply 1 of 148, by PowerPie5000
These are the games i remember off the top of my head (i know there's probably plenty more!):
Toonstruck (speed bug with one or two puzzles)
Theme Park (too fast overall)
Kings quest 7 (speed bug with one or two puzzles)
EDIT:... Outlaws used to run way too fast with my PIII rig, but now it's mysteriously running fine 😮.
Reply 2 of 148, by d1stortion
Outlaws?? Like, the LucasArts FPS? That played even fine on a modern rig with software rendering iirc...
Reply 3 of 148, by PowerPie5000
It runs like lightning on my 850MHz PIII rig (software mode) so it would be interesting to see how fast it runs with my i5 3570k (if it works at all) 🤣... I have the original big box release so maybe it just needs patching.
Reply 4 of 148, by robertmo
i guess forced vsync may be the key for outlaws 😉
anyway all dos games need dosbox on modern systems so your list will be useless 😉
Reply 5 of 148, by d1stortion
There are enough people on this forum who play games on vintage hardware, FYI.
Reply 6 of 148, by robertmo
vintage hardware handles games properly 😀
Reply 7 of 148, by d1stortion
Are you trolling or what? Looking at your registration date, one should think you would know better. There exist 386 games that will run too fast on 486 CPUs and so on and that is what this thread is for.
Reply 8 of 148, by PowerPie5000
It seems to run ok on my Compaq Presario laptop (P233 MMX, 32MB RAM, 2MB MagicGraph 128XD, ESS audio and Win95c)... But i don't like the screen much (too much motion blur).
Reply 9 of 148, by leileilol
Space Quest IV - any time a sequel police is on the screen
Even the original release runs fine here with 3ghz.
What the heck is going on
Debian's fucked
Reply 10 of 148, by robertmo
leileilol wrote:
Even the original release runs fine here with 3ghz. What the heck is going on
vsync?
Reply 11 of 148, by filipetolhuizen
3GHz here too. It runs fine with Vsync on or off.
Reply 12 of 148, by PowerPie5000
leileilol wrote:
Space Quest IV - any time a sequel police is on the screen […]
I gave it another go and it's now running fine on my PIII 😕, although i've changed the graphics card a few times since i last played it! I think it ran way too quick on my ATI Rage Fury Maxx if i remember (it was some time ago) .
Anyway, i can knock that one of the list 😀
Reply 13 of 148, by d1stortion
On that note, I tried that D3D patch on both ATI and Nvidia, got only a garbled mess with both. Pretty useless.
Anyway, more games that need specific CPUs?
Reply 14 of 148, by j^aws
Off the top of my head: Wing Commander, Ultima 7 and Zool. Maybe Micro Machines 2 SE, though, IIRC, that one seemed to work okay with specific fast CPU/ FSB options...
Reply 15 of 148, by filipetolhuizen
Double Dragon 1 will lock up before entering the final confrontation and player 2 will have fewer moves if run on anything above than XT.
Reply 16 of 148, by badmojo
Syndicate crashes for me with a fast CPU (P75 133 and Pentium 166 MMX tested) when using a sound blaster (tried various creative cards). Anyone else every had that issue? It makes a loud sound like breaking glass and then freezes - quite scary the first time it happened!
Reply 17 of 148, by elianda
Sound with Day of the Tentacle doesn't work on a fast CPU >P166MMX properly anymore, probably other iMuse based games too.
I also have problems with Monkey Island with Roland MT-32 sound on fast CPUs, it's completely garbled.
Hi Octane has a speed problem.
Maniac Mansion and Zak McKracken have a problem as soon as there is a timed riddle (like after flushing the pool water)
Unreal / Unreal Tournament has a problem on very fast systems where the actor begins to slide (rounding errors?)
Lemmings the Tribes requires a HDD smaller than 504 MB or the copy protection checksum calculated by the installer is wrong.
Warlords2/Warlords2 Deluxe crashed on startup when the PC is too fast.
Youtube Channel
Reply 18 of 148, by d1stortion
Sliding players in UT have nothing to do with CPU speed, but with flawed S3TC textures. It can be fixed by not using some of those textures and patching the others, see here.
UT has a major problem with power saving techniques like Cool'n'Quiet though.
Reply 19 of 148, by Gamecollector
FIFA 2002 - ctd on fast CPUs (1,5 GHz is fine, 3 GHz - ctd).
