First post, by exofreeze
exofreeze
Offline
- Member
I have Skunny Lost in Space installed in dosbox 0.74. If I turn sound blaster effects on in the game, the first time I do a move that uses an effect, like a jump, the game crashes. This is notated on the compatibility page.
I have tried changing the sbtype to sbpro1 and also disabling it and trying the gravis (which isn't detected).
I tried some random things like messing with cycles and loadfix as well.
None of it has helped so far, so I figured I'd post the issue here.
