Reply 20 of 33, by Scylla
- Member
wrote:Are the analog RGB signals sent from one card to the next over that cable? If so it may be advisable to use an 80-pin ultra ata cable as it is 75-Ohm just like video cable.
I think you mean a 80 conductor 40-pin cable 😉
The resistance shouldn't matter much considering it's such a short cable. Howerver, I'm curious as to how to peel a 80 conductor ribbon cable without tearing it and how to twist it correctly. If I had one to spare, I'd test that immediately 🤣
Now you say it, there should be video signals running in that cable. SLI works making each Voodoo2 card render alternatively the lines of the display, so the video information should travel through the SLI cable.
