VIDEO CARD Custom S3 Trio Patch (DOSBOX)
Here you can discuss the development of patches.
Postby s3freak » 2013-4-07 @ 18:02
This is the area of DOSBox which I have spent the most time on and therefore my username!
The patch features the following:
- 24-bit colour support - I just wanted to experiment with this. It can be disabled by using machine types vesa_no24bpp or vesa_nolfb_no24bpp in dosbox.conf as it can confuse a few DOS apps such as SVGATest and SEA picture viewer.
- Some additional modes, including 1600x1200 - The mode list has been heavily customised to my own liking.
- Refresh rates for VESA modes inside DOSBox - The refresh rates can be set under a new section called vesa_refresh in dosbox.conf - This allows you to match the refresh rate inside DOSBox to your monitor. This only works for VESA modes, not standard VGA, EGA, CGA, etc.
- Extended text modes (80x60, 132x25, 132x43, 132x50 and 132x60), 9 pixels wide per character, which improves text mode readability, compared to 8 pixels wide - My very first graphics (Trident T9000i) card has such extended text modes.
- VGA text mode with 9 pixels wide per character for S3 Trio, not just standard VGA - This is the behaviour of other virtualisation solutions, such as VirtualBox and VMWare, and real graphics cards, including my real S3 Trio 64 / Vision 968.
- 512KB, 1MB, 2MB, 4MB and 8MB video memory options (4MB default). Therefore you can run Windows 3.1 in 1024x768 32bpp, with 4MB, etc. You cannot use more than 4MB in Windows 3.1 or else it will crash on startup. I have S3 Trio cards with with 4MB.
- Smooth page flipping under VBETest - Taken from DOSBox MB6.
- 64KB aligned page sizes - Taken from DOSBox SVN.
Credit to the original authors for the last 2 features.
You do not have the required permissions to view the files attached to this post.
My 486 is my real DOSBox, as well as my customised DOSBox!
I am not very active on VOGONS, please PM me if you need a quicker response!
User avatar
s3freak
Re: S3 Freak’s Custom S3 Trio Patch
Postby Dominus » 2013-5-09 @ 20:04
Moved to the patches forum viewforum.php?f=41
User avatar
Dominus
DOSBox Moderator
Re: VIDEO CARD Custom S3 Trio Patch (DOSBOX)
Postby Timbi » 2018-11-13 @ 15:10
and how to load it into the DOSBOX-X?
User avatar
Timbi
Postby Yesterplay80 » 2018-11-13 @ 15:46
This patch is so old, it certainly won't apply anywhere any more.
My full-featured DOSBox SVN builds (without debugger) for Windows: Vanilla DOSBox and DOSBox ECE (Enhanced Community Edition)
User avatar
Yesterplay80
Postby Timbi » 2018-11-13 @ 19:30
Welp, I'm interested in 24bpp mode even if without 32bpp. Just to line it with other apps inside the guest.
User avatar
Timbi
Postby s3freak » 2018-12-25 @ 12:27
Yesterplay80 wrote:This patch is so old, it certainly won't apply anywhere any more.
This is for DOSBox 0.74, which this patch is originally for, where I fixed a few bugs recently during my project to patch a S3 Trio / Vision BIOS on actual cards. I have not been updating the base DOSBox build ever since, especially when my focus is now on actual hardware.
User avatar
s3freak
Postby abchines » 2019-7-26 @ 12:54
How to install it?
abchines
Postby zirkoni » 2019-7-26 @ 16:01
abchines wrote:How to install it?
Seriously?
It's a patch for the source code. You apply it on the source code and then compile the DOSBox executable.
User avatar
zirkoni
Postby abchines » 2019-7-27 @ 07:28
Seriously?
Hallo! I know how to compile the souce, but I don't know where should I apply the patch.
abchines
Postby zirkoni » 2019-7-28 @ 06:54
First you checkout the DOSBox source.
Then on Linux you'd do something like this:
Code: Select all
patch -p0 < custom-vga-s3.patch
On Windows you could use TortoiseSVN GUI -> apply patch.
This patch was created in 2013 so it probably won't apply to the current SVN source. You can try solving conflicts manually or you can checkout some old 2013 revision of the source that won't have any conflicts.
Patch format: https://en.wikipedia.org/wiki/Diff#Unified_format
User avatar
zirkoni
Postby abchines » 2019-8-01 @ 04:30
zirkoni wrote:First you checkout the DOSBox source.
Code: Select all
Thank you very much.
abchines
Return to DOSBox Patches
Who is online
Users browsing this forum: No registered users and 2 guests
