Suggestions for Desktop pentium M build
First post, by nforce4max
I recently bought a MSI 915GM Speedster-FA4 and with school plus family drama keeping me drained I haven't put much thought into this build other than the graphics card. Already I have on hand a spare PM 770 and will have to buy everything else like case ect so I am open to suggestions such as case ect.
Uses, retro gaming and general storage backup running XP.
Reply 1 of 31, by Standard Def Steve
I use the same motherboard for my Pentium M rig. It hosts a GTX-260 Core216 and a PM 745 @ 2.4GHz. Very fast and stable combination. In fact, it's always felt (and benchmarked) faster than any of the single-core K8 machines I've built. I'm not sure how much of this has to do with Win7 being the OS; my single-core A64 systems still run XP.
The ICH that the Speedster uses actually supports AHCI, despite being only a SATA-150 controller. You could use something like a 60GB SSD as your boot drive if you wanted to.
For memory, I'd recommend dual-channel DDR2-800 memory instead of DDR1-400. DDR2-800 will downclock to 533MHz for a perfect 1:2 FSB:DRAM ratio. At 533MHz, most PC6400 modules will let you run them at CAS 3-2-2-8, which will boost performance.
Not sure what your budget is, but I've always wanted to put my PM rig in a Silverstone Temjin TJ08-E mATX case. It's currently in an Antec 300 midtower, which, while definitely not as sexy (or quiet) as the Temjin, does the job.
I purchased two Speedsters, neither of which came with a proper S479 HSF. I had to remove the heat spreader from one of my old P4s, attach it to the PM, and then mount a standard S478 HSF on it. This seems to work well, as CPU temp never exceeds 34 deg.
Reply 2 of 31, by nforce4max
Thanks for the tip about the cooler, I thought that if the bracket sat a little lower than a standard 478 mount that the cooler would be lower as well but I will fix that. I don't like ddr1 anyway (costly) and for storage I will be using 2.5 sata 2 gen era drives as I will have a few on hand as I am salvaging some for a friend. I wasn't sure about the graphics card but it managing a 280 is a surprise so I will dig a little deeper when I can. I would have it done soon but car trouble makes things difficult >.<
So far I will get an antec psu (380-550w) on the cheap and use 2.5 drives. Will have to look for something that can be easily modded for cooling. Got a pm 770 on hand (hopes for 2.5ghz+).
Reply 3 of 31, by nforce4max
Finally got the rig up and running, took ages to get enough parts. So far I am running a pm 770 at 2.4ghz. Got desperate and bought a open boxed 4650 gddr3 but at least it has dx10. Beyond that it has almost 1TB worth of 2.5 sata drives 🤣 and the case looks great for being a no name generic (all black).
Reply 4 of 31, by shamino
At one time I was thinking about building a low power gaming capable PC for use during power outages. It would be powered by a modified UPS with large batteries attached. I never went forward with it but the Pentium M seems like a great candidate for that. I wish they were more common.
Our outages range from hours to days. It hasn't happened recently but when it does it gets very boring.
Reply 5 of 31, by nforce4max
I like the board as it has great os support, Win95 all the way up through to Win 7! The pm cpu its self isn't that hard to come by but the desktop boards are very rare 🙁 Had to import mine from the UK.
For very low power build look into an e350/450 amd apu, stock at 18w but you can undervolt for extra power savings.
Reply 6 of 31, by northernosprey02
Playing games while power outages? 🤣, seems not sense for me. Laptop like desktop PC.....
Reply 7 of 31, by GL1zdA
I don't think the 915 chipset and PCIe graphic cards are supported in Win9x.
getquake.gif | InfoWorld/PC Magazine Indices
Reply 8 of 31, by nforce4max
Hehehe then you haven't seen this!
http://www.msi.com/product/mb/915GM-Speedster … ver&os=Win%2095
Reply 9 of 31, by northernosprey02
Are you sure it working? I can only see support Windows 2000/XP/2003 only when I go to Win98 SE driver.
Reply 10 of 31, by cdoublejj
is an OCed P4 faster than an OCed Pm?
Reply 11 of 31, by nforce4max
Depends on which one plus a PM build has more of cool factor than a p4 rig. 😎
In some benches it will be very hard for a oced p4 to completely beat a maxed out pm. Already gunning 2.48ghz and still testing 😁
Reply 12 of 31, by shamino
True, laptop would be efficient. But my laptop is old and weak, and buying a better one would be expensive.
But buying oversized batteries for the UPS is also expensive, so if I look at what everything costs a low power laptop might make more sense. I never got serious about it because of the cost.
Reply 13 of 31, by nforce4max
Laptops don't do this cpu justice 😮
Topped out at this as I go any higher than 160mhz on the chipset I lose sata functionality 😮 Runs fairly fast 😁
Went by West (town in Texas) and got the creepiest vibe 😵
Reply 14 of 31, by cdoublejj
I have a 1mb cached 800mhz bus p4, so i guess that makes it a presscott? it's oced 600 mhz. would i loose out on gaming performance going to Pentium m? can PM OC well? can hit 3+ ghz?
EDIT: to the poster above me you image is too small to see the text.
Reply 15 of 31, by NJRoadfan
I've been through a 10 day outage. The solution is called a generator with plenty of fuel on hand. Keep the laptop batteries charged, the food cold (much more important than any computer in such a situation), and some lights on in the dark.
Reply 16 of 31, by Standard Def Steve
Nice! My Speedster and PM-745 will not run one MHz over 2.4GHz/133. I'm not sure if the CPU or board is stopping it, but it will not boot into Windows at 2.41/134. Yet at 2.4/133, it's 101% stable. I actually thought that was a "feature" of the mobile i915, but apparently it isn't. 🙁
I highly doubt that a PM could hit 3GHz. The absolute best PM overclocks I've seen on the 'net are around 2.8GHz with i875 boards and socket adapters.
An overclocked PM would definitely beat the fastest P4s in gaming performance. So long as I stick with single-threaded games, my PM @ 2.4GHz actually manages to outperform my 939 X2-4600!
Reply 17 of 31, by cdoublejj
I was playing 1 of the STALKER games and NFS Prostreet, could the PM handle that? also can it do HD youtube when OCed?
Reply 18 of 31, by Standard Def Steve
Haven't tried playing NFS ProStreet on it, but based on the rather low system requirements (2.8GHz P4, 512MB RAM, FX5950/Radeon 9500), I'd guess that pretty much any Dothan would be able to handle it with a good graphics card.
My machine has no problem with YouTube HD. CPU usage stays nice and low even with 1080p clips. Course, the GTX-260 does all of the heavy lifting.
Reply 19 of 31, by nforce4max
Honestly a good PM build can handle a lot of the newer titles but only with a decent graphics card, after all there are still p4 systems running current titles. I'll take a PM over any AMD C or E series any day. Plays Bioshock great so I can't complain.
If only there was an option for adjusting the volts then getting 2.6-2.8 would be no issue on some samples.
