First post, by Mau1wurf1977
I have spent all day figuring out how to burn a CD-ROM from the GOG.com version of Pinball Illusions (It comes with CUE/BIN files + 50 or so OGG files for CD Audio).
20+ non working CD-Rs later I believe I have figured it out.
However I ran into a roadblock when trying to run it on the PC. The game installs just fine (by running INSTALL.EXE from the CD).
You start the game with ILLUSION.BAT and on the PC I get this error screen:
However...
When I mount the CD in DOSBox, the game runs perfectly. All the Music is through CD-Audio and tracks change correctly.
Also when I disable HIMEM.SYS AND EMM386.EXE in CONFIG.SYS the game does run on my PC:
So I'm wondering what could be causing this. I have tried only disabling EMM386.EXE and I get the same error.
I am running MS-DOS 7.1. The machine has a Pentium MMX 133 and 64MB of RAM.
AUTOEXEC:
SET SOUND=C:\SB16
SET BLASTER=A220 I7 D1 H5 P300 E620 T6
SET CTCM=C:\CTCM
C:\SB16\AWEUTIL /S
C:\SB16\MIXERSET /P /Q
SET PATH=C:\DOS
LH C:\DOS\DOSKEY.COM
LH C:\DOS\MSCDEX.EXE /V /D:CDROM001 /L:D
LH C:\DRIVERS\LOGI730\CLOAKING.EXE
LH C:\DRIVERS\LOGI730\MOUSE.EXE
CONFIG
DEVICE=C:\CTCM\CTCM.EXE
LASTDRIVE=Z
DEVICE=C:\DOS\HIMEM.SYS /TESTMEM:OFF
REM DEVICE=C:\DOS\EMM386.EXE RAM
DOS=HIGH,UMB
DEVICE=C:\DRIVERS\CDROM\CDROMDRV.SYS /D:CDROM001
FILES=40
My YouTube channel
Reply 1 of 16, by Mau1wurf1977
PS: Tried with MS-DOS 6.22 and I'm getting the same issue. Pinball Fantasies also has the same issue.
My YouTube channel
Reply 3 of 16, by Mau1wurf1977
5u3 wrote:
Did you already try disabling C:\DRIVERS\LOGI730\CLOAKING.EXE?
Hmm I REM'd it out but no luck...
However I believe to have narrowed it down to SETSOUND.EXE
The first time the game starts after installing it runs SETSOUND.EXE on its own and crashes.
So after I booted with no memory managers, I ran it once, and now it works. After the first time you run SETSOUND.EXE it also creates a CFG file which you can simply edit to change the driver. But you can't change the quality setting without SETSOUND.EXE I'm afraid.
But running SETSOUND.EXE again crashes it again...
My YouTube channel
Reply 4 of 16, by JayCeeBee64
Rank Retired
Retired
(Deleted. No longer relevant anyway)
Ooohh, the pain......
Reply 6 of 16, by Mau1wurf1977
Haven't tried this workaround, but as I described above, booting with no memory managers and running SETSOUND.EXE once fixes the problem 😀
My YouTube channel
Reply 7 of 16, by Jorpho
JayCeeBee64 wrote:
As crazy as it sounds, this works! uide.sys replaces your CD-ROM driver and the configuration options add a 25MB file cache. And for reasons I cannot imagine, this fixes the problem (I tried this on my Pentium 166MMX with 64MB of RAM). See if this works for you, Mau1wurf1977.
How fast is the CD-ROM drive on that computer of yours? Maybe it's some kind of weird race condition/timing issue.
Reply 8 of 16, by Mau1wurf1977
I can confirm your workaround works 😀
Because Pinball Illusions crashes even when you have configured a Sound Card successfully before.
Scratching my head how you found this fix though 😁
Good find!
My YouTube channel
Reply 9 of 16, by Mau1wurf1977
Ok I have another question regarding only Pinball Illusion Deluxe!
The CD-ROM I burnt plays Audio CD music AND tracker music at the same time. It does this on my Pentium and also in DOSBox when the disc is mounted.
However the GOG.com release (when running their own shortcuts) works fine. So I digged a bit deeper and noticed GOG.com used a SVN of DOSBox. I replace the DOSBox exectuable with a standard one and now it also plays Audio CD and tracker music simultaneously.
What is the source of this problem and what changed does the SVN have to resolve it?
Update: Found a previous thread on VOGONS talking about this game manipulating the Sound Card mixer. This makes totally sense.
However I'm wondering why this mixer feature doesn't work on the AWE64 Gold. I could try out a Sound Blaster Pro or Sound Blaster 16 tomorrow, but just wondering...
My YouTube channel
Reply 10 of 16, by Mau1wurf1977
Ok so I tested this with a Sound Blaster Pro 2 and the issue remains. It plays CD Audio and tracker music simultaneously.
Is this just how the game is?
Still wondering what the SVN version of the GOG.com version supplied does in order to resolve this. Why would it fail to control the mixer on a real DOS PC?
My YouTube channel
Reply 11 of 16, by ripsaw8080
Rank DOSBox Author
DOSBox Author
http://sourceforge.net/p/dosbox/code-0/3631/
SVN has audio channel control, which is actually a cdrom driver function, unrelated to the sound card. So, I would guess that you're using real MSCDEX; but are you using a generic cdrom driver, such as oak, or one specifically for your cdrom drive?
Reply 12 of 16, by Mau1wurf1977
Oh I see, so the issue is related to the CD-drive / CD drivers.
I'll try a few drivers that I have accessible.
Yes I'm using MSCDEX (DOS 7.1 version). The driver is this UIDE.SYS as suggested in the discussion above. It resolves the game crashing at start-up...
My YouTube channel
Reply 13 of 16, by Mau1wurf1977
Thanks ripsaw8080, that fixed it 😀
Went back to my trustry Toshiba CD driver and now the games behaves correctly! Still no idea what problem the game has with the memory managers, but as long as I boot clean (NO HIMEM.SYS and AND / OR EMM386.EXE) everything works fine.
My YouTube channel
Reply 14 of 16, by Mau1wurf1977
Here a video of the result!
http://youtu.be/fY3b3AwzAK8?t=11m6s
This is the GOG.com version of Pinball Illusions. The first part explains how to burn the CD (quite a few steps as you need to convert the audio files, extract the data and merge them into a mixed mode CD).
The second part (where the link above starts) shows me installing the game from the CD, configuring the audio and game options and then playing around with a few tables.
PS: I recommend playing the game without XMS and EMS and otherwise it can be quite buggy, not reading keyboard input, getting stuck and things like that.
My YouTube channel
Reply 15 of 16, by JohanL
Real old thread I stumbled on. I'm one of the programmers of the game. If I recon it will play the cd track once and then start playing the mod. If mscdx (or what the cd driver was called) is reporting track length 0 it will just play mod. I remember this as game was cracked but they missed to fix this so the music was not working correctly.
Reply 16 of 16, by mkarcher
Mau1wurf1977 wrote on 2013-04-30, 15:25:
You start the game with ILLUSION.BAT and on the PC I get this error screen: […]
However...
It's a bug the the DOS extender used with Pinball Illusions. If EMM386 is loaded, it runs in VCPI mode (which is the correct and only operation mode available with EMM386 loaded). VCPI mode crashes if too much memory is available (IIRC the limit is between 32 and 56MB). That's why loading a big CD cache helps.
