Nvidia's framerate limiter
First post, by d1stortion
Anyone ever messed with this? In theory this could be a pretty nice tool for old game compatibility on new graphics cards, while avoiding the input lag of VSync.
Some games display tearing way beyond what can be called normal at 100+ FPS (GoldSrc games are the best example from my experience), and 120Hz monitors are still fairly uncommon. Also, a number of games simply look better with 30-40 FPS than with 60+, and the tool would obviously make the graphics card run cooler and prevent coil whine when it's not trying to draw 300+ FPS.
Reply 1 of 27, by robertmo
Thanks for noticing that.
It's great nvidia finally made it available (actually over a year ago). I already wrote somewhere about problems with many games making card extremely noisy when entering game's menu as they don't have any limiter for menus.
vsync making menus 60fps was still making card very noisy. The game was 30fps and rather silent. I remember star wars force unleashed, wolfenstein, trine and i guess many more.
Reply 4 of 27, by d1stortion
vsync making menus 60fps was still making card very noisy. The game was 30fps and rather silent. I remember star wars force unleashed, return to castle wolfenstein, trine and i guess many more.
Yeah, coil whine is a huge problem. I guess it sucks if you pay big money for a new graphics card and run into something like this. It's on my old 9800 GTX+ as well. Unfortunately I couldn't get this feature to work so far, so I'm suspecting it's only for newer cards... 🙁
keropi wrote:
is this limiter the "new vsync" option they said they added? adaptive vsync? a setting in nv control panel? wouldn't mind turning this ON on my 660ti 😉
No, Adaptive VSync is supposed to turn VSync on and off depending on the situation or something. For the feature I'm talking about you need the program Nvidia Inspector, because they don't have the option to set it in the driver so far.
Reply 6 of 27, by robertmo
Based on what they said in the above forum link
I think Adaptive VSync turns vsync off when fps is lower than refreshrate and turns vsync on when it is higher (so it doesn't slow down what is already slow)
Reply 7 of 27, by d1stortion
Mau1wurf1977 wrote:
Often the whine actually comes from the PSU. But yea it's quite annoying. I had a very bad case and swapped the card out at the shop because of this.
Even worse is when you can't play old games on the new card because of tearing...
Reply 8 of 27, by robertmo
Doesn't vsync handle that?
Reply 9 of 27, by Mau1wurf1977
Yes but it introduces input lag.
It's much better on a CRT with higher refresh rates.
Or 120Hz LEDs of course...
My YouTube channel
Reply 10 of 27, by d1stortion
I think it would be pretty cool to have an old card in another PCIe slot and then be able to switch to it depending on the game 😁 but everyone is only about SLI/Crossfire, dedicated PhysX cards etc 🙄
Reply 12 of 27, by PowerPie5000
You can get coil whine with some PSUs if they're pushed, but i find more often it's the GPU or in some cases the CPU VRMs on the motherboard... I've only ever had one PSU with coil whine and it was a cheap and nasty "builder series" Corsair CX600 😒.
I RMA'd a 'HIS 7950 IceQ Boost Clock' a while back due to loud coil whine. The replacement has been perfect ever since! Coil whine is a joke these days and shouldn't even exist with all the solid type components that are supposedly being used... And coil whine isn't really classed as a fault either.
Reply 13 of 27, by robertmo
btw here is my old thread about the problem
Paused game -> hot (noisy) gfx card
anyway fps limiter works on my nvidia gtx 285 with Nvidia Inspector win7 (30fps) so at least my problem is solved 😉
Reply 14 of 27, by Stojke
I have GTX295 maybe i can help you analyze the problem?
Reply 15 of 27, by robertmo
sorry for confusion, i edited my post,
it is d1stortion that has the problem not me
Reply 16 of 27, by robertmo
anyway d1stortion it looks you can just get some cheap used 285 as it is supported 😀 I guess 480/580/680 and upcoming 780 will work too 😉
Reply 17 of 27, by d1stortion
Did you try it with VSync on and off? I tried very few games, namely NFSU2 and Skulltag/Zandronum and they didn't work with the feature. Only VSync worked for capping the framerate but that often sucks, lots of input lag.
Also 9800 and 285 are close in terms of architecture so it normally should work imo. Well when I feel like it I'm going to try it again with some new drivers 😀
Reply 18 of 27, by robertmo
30fps confirmed by fraps is definitely not reduced by vsync 😉
btw i am using nvidia Inspector 1.9.7.1 and i wonder where is this file from as official site doesn't seem to be updated since Februar 17th, 2011
http://www.orbmu2k.de/
Reply 19 of 27, by d1stortion
1.9.7.1 is the newest I think. By the way another great feature in that tool is SGSSAA with negative LOD, top notch image quality if the card can handle it 😀
