Rename Serial Ports (COM4->COM5)
First post, by Korrupt
Hello,
I am using the DOSBOX MEGABUILD 6 from h-a-l-9000 with porttalk extension and so on.
Everything works fine and I am really happy that I can use my old programs on new Windows 7 64bit.
On my old DOS-PC I had an adapter to add 4 more COM-Ports (then I had the onboard com1/2 and the external com5,6,7,8 - no com 3/4). The problem ist that the software I have tries to communicate to COM5 which should be COM4 or COM3 in DOSBOX.
Is there any possibility to rename COM4 in DOSBOX to COM5 or COM6/7/8? Actually I only need 4 serial ports at maximum but I need to rename them.
Thanks for help,
Reply 1 of 22, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Only in source. Also depends wether it accesses the ports directly via I/O or in the DOS device way.
1+1=10
Reply 2 of 22, by Korrupt
Hi h-a-l,
thanks for quick reply. Yep that's what I was afraid of. I don't know much about these things but I am willed to try my best.
I don't know how it's adjusted in the software but I have some information:
1) As I heard the software can't run on Windows XP or newer because direct access on serial ports isn't allowed by these OSs (I think that's the problem which was solved by the porttalk driver)
2) I attached the driver of the adapter from my old DOS-PC. I think the .sys file isn't very interesting but the .opt file seems to have some useful information about how the adapter was configured. Actually I am not able to interpret it. (I renamed .opt to .txt to upload it, in fact it is an .txt file)
Hope that helps,
Reply 3 of 22, by Korrupt
Whoops, i attached the edited file. I tried to change
# define DOS device names
/D:COM5
to
/D:COM3
but that didn't have any effect (the driver isn't loaded in dosbox, i know, but I thought that the software makes use of it, too...however)
So, in the original file it was /D:COM5
Reply 4 of 22, by Korrupt
Hello again,
sorry for tripple post but I can't see any edit function. I now talked to one of the software developers who said that the program uses the DOS-INT 14 call.
"int86(0x14, &regs, &regs)"
Reply 5 of 22, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
In that case it may help to override the port number at the other side of this BIOS call.
This is the piece of code:
static Bitu INT14_Handler(void) {
if (reg_ah > 0x3 || reg_dx > 0x3) { // 0-3 serial port functions
// and no more than 4 serial ports
LOG_MSG("BIOS INT14: Unhandled call AH=%2X DX=%4x",reg_ah,reg_dx);
return CBRET_NONE;
If reg_dx is 4 then you want to change it to 3.
1+1=10
Reply 6 of 22, by Korrupt
Okay, i hope I understood this right. I found that piece of Code in the dosbox source.
Now you want me to change my software... but unfortunately the programmer of it was kind of lazy and didnt make Backups after every change... Which means that I only have the executable which is up2date and some older source code. I'll try to find the newest source but that may be a problem.
If there's any possibility to change it in dosbox source I would prefer that.
Thanks for help up to here.
Reply 7 of 22, by Jorpho
Have you tried looking at the binary code of the executable with a hex editor? Maybe you'll be lucky, and the relevant byte will be conveniently accessible.
Reply 8 of 22, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
You can compile your own version of DOSBox with this change.
1+1=10
Reply 9 of 22, by Korrupt
Ah, I think I understood. You meant it like if reg_dx is higher than 3 then change it to 3. Okay, I'm not really into coding but I'll try to find a solution.
Reply 10 of 22, by Korrupt
Okay, I don't know how to code this. Anyone here into C++ and can fix it the way described?
Reply 11 of 22, by Jorpho
Korrupt wrote:
Whoops, i attached the edited file. I tried to change […]
/D:COM5
to
/D:COM3
I missed this before. Are you saying that even after you make this change, the program is explicitly giving you an error saying that it cannot access COM5?
It is possible you may need to load the .sys driver in the end, in which case you may have to boot MS-DOS inside DOSBox.
Reply 12 of 22, by Korrupt
Hi jorpho,
I don't need to use the serial adapter which belongs to the driver. I think that loading the driver wouldn't solve the problem because the Int14 call ist used but I may give it a try.
However, still looking for someone who could change
return CBRET_NONE;
To something like
If ( reg_dx > 0x3)
reg_dx = 0x3;
Would it work that way?:
reg_dx = 0x3;
return CBRET_NONE;
Reply 13 of 22, by Jorpho
Why not try it and find out? 😖
Reply 14 of 22, by Korrupt
Actually I am ony my way to test it but I got stuck at building following this guide: http://www.dosbox.com/wiki/Building_DOSBox_wi … _C_2008_Express
I did everything the way described. I excluded driver.cpp and driver.h and ne2000 because there were some errors while compiling and I don't need these functions.
Now it says 1>LINK : fatal error LNK1181: cannot open input file 'sdl.lib' but I think I set up the linking in options the right way... 😒
Reply 15 of 22, by Korrupt
Okay, got this error solved. Still some others to go, hard work to search all the right dependencies as I am an unexperienced guy.
Stay tuned
Reply 16 of 22, by Korrupt
Wow, after searching all the required files I finally got a working dosbox.exe compiled. Placed it into the dosbox folder and replaced the original one, works like a charm.
Next step is to try my software. I will inform you as there are new results. So far, thanks for help!!
Reply 17 of 22, by Korrupt
Hello again,
Yesterday I had the chance to test the changes and.... It works!! The "port-forwarding" works and the hardware is recognized and initialized.
Unfortunately there is now a problem with COM1 and COM2. There are a few errors kind like this:
Serial 2: Errors: Framing 0, Parity 0, Overrun: RX 1<IF0:0>, TX: 0, Break 0
Serial 1: Errors: Framing 0, Parity 0, Overrun: RX 2<IF0:0>, TX: 0, Break 0
Rxdelay is set to 300. CPU Cycles is 300.000. Any ideas?
And does anyone know where to find kind of donation details to thank for the provided solution?
Thanks,
Reply 18 of 22, by Qbix
Rank DOSBox Author
DOSBox Author
300 000 is a lot of cycles... was this software written for a high end pentium originally ?
Water flows down the stream
Reply 19 of 22, by Korrupt
yeah it's propably the problem because it's the first time I used this setting.
Before I used AUTO but on the main screen (programm which communicates via com ports to hardware) the screen build-up was very slow. In addition there is an optional optimation programm (which doesnt make use of the COM ports) which runs under lower CPU Cycles (where te screen build-up is pretty smooth) very slowly. In this optimation software there is much to be calculated and that may be the reason for its slowness. This slowness only appears with low manual cycles, I think with AUTO the dosbox adjusts the value by itself.
I know about the possibility of CPU Cycles up and Down but I thought that this might be the easier solution.
Do you think that the high cpu cycles might be the problem?
Actually i don't know what it was written for but I may ask the original developer.
