First post, by kithylin
- l33t
There's a couple threads on this probably but some are difficult to read and I've been trying to understand this myself for a long time.
I have a retail copy of Descent2 (Original disc), and Carmageddon SPLAT Pack (also Original disc).
What I'm trying to find out is they have a "3dfx" alternative mode, and if I remember correctly, this was possible to run inside dos -WITHOUT- using Win9x.
The problem is this was many years ago and I didn't step in to the 3D field until the voodoo2 era and Win9x and Direct3D games.
So my question: If I want to use this 3D mode in DOS, with 3DFX mode, Can someone tell me -exactly- which video card I need to do this?
Also, are there any special software / TSR's / Drivers necessary to run via autoexec.bat / config.sys for these cards to work, -BEFORE- loading the game's 3DFX EXE?
Or if I can locate one of the cards, can I just stick the card in and go run the EXE and it instantly works?
I would guess and assume an original voodoo1 may work, those are a little hard to find these days though. Would a voodoo2 work? Those are easier to find, but not always cheap today. If a voodoo3 would work, I'd just use that over anything else, they're found cheapish and commonly today.
I just want to see this mode work under dos. I've never, ever, ever seen it running anywhere and supposedly it was possible. I also have the original Quake-1 CD-ROM Disc and I believe it supported a 3dfx mode under DOS too.
