First post, by Tolenci
Hi
I downloaded the WA2 tides of darkness torrent from TPB a few days ago, and after alot of hassle i got it running on dosbox v 0.74. But when i run it and press the single player, it wants the CD, which i obviously don't have.
Now usually you have to mount a torrent game with for example daemon tools ofc. But this installation was pretty straightforward with no mounting.
First time trying to use DOSBOX or doing anything with a cmd window so I'll need some easy step by step instructions on how to fix this, since all the other post helps about this have been too complicated for me to use....
THX for the help in advance!
And if needed i can paste the installation instructions for the torrent here so you'll see what i did with the installation. And also tell you more about how i ran the exe on dosbox...
