Reply 40 of 54, by leileilol
- l33t++
you know, in a thread with the title of various non-pentium processors, how about not spoonfeeding the same 'minimum requirements is pentium' every post?
wrote:you know, in a thread with the title of various non-pentium processors, how about not spoonfeeding the same 'minimum requirements is pentium' every post?
Cite specific examples or it didn't happen.
wrote:I doubt any game released in 1996 would run any better than a slideshow on a 386 system even with a FPU. […]
wrote:387 is just the co-processor, but yes, a 386dx system would need a co-processor to run Quake.
Minimum requirements calls for a Pentium 75 or better according to this
wrote:When they make up the minimum specs for a game, they don't mean minimum to execute, they mean minimum to be playable so using that standard, Quake is not usable with a 386 even if it does boot and run at a snail's pace. If they had published the minimum specs to run as a 386 with 387 FPU there would have been hell to pay.
Now get the fuck out. 😀 You have nothing new to say/contribute. You're only pissing us off just for kicks.
wrote:wrote:I doubt any game released in 1996 would run any better than a slideshow on a 386 system even with a FPU. […]
You have no idea what you're talking about. I was only responding to a message that was directed at me.
Hmm, I've been thinking about it for a bit, and you know what I would like to see? Install Win95 on a 386 w/ 387, then try running Quake II. 🤣 See how many minutes it takes to render a frame. 😁 It won't be even remotely playable, but hey, why not give it a shot?
wrote:Hmm, I've been thinking about it for a bit, and you know what I would like to see? Install Win95 on a 386 w/ 387, then try running Quake II. 🤣 See how many minutes it takes to render a frame. 😁 It won't be even remotely playable, but hey, why not give it a shot?
I'm not entirely certain if it does or not, but if Q-II uses any 486 or Pentium specific instructions, it will probably crash when it gets to an instruction that the 386 can't execute.
Uy! a 386 + Quake 2... i really wanna see too!! sadly im very busy with work right now, but as soon i can, i will try to do!
I have a 386+387, 16mb ram and 1GB CF card, but only DOS+win3.1
By the way, finally today I get the AMD 5x86, and is amazing!!
The performance is exactly the same that a 486 at 133mhz, jeje, the "5x86" is nothing... jaja
The 33mhz difference helps a lot in emulators, specially Callus, now callus is fully playable
With the DX4100 in 3dbench i get 71.2 now 90.4, very good score
I really hope one day, i can get a Cyrix 5x86 to compare against the AMD
Sadly it seems my motherboard not work good at 40mhz, I can overclock the 5x86 to 160mhz, but the machine freeze when loading DOS
Even if disable L2 or lowering timings, still freeze 🙁
wrote:wrote:Hmm, I've been thinking about it for a bit, and you know what I would like to see? Install Win95 on a 386 w/ 387, then try running Quake II. 🤣 See how many minutes it takes to render a frame. 😁 It won't be even remotely playable, but hey, why not give it a shot?
I've heard of people running it on their 486 boxes, so I'm fairly certain that it doesn't take advantage of any Pentium-specific instructions. As for 486 instructions, I don't exactly know for sure. Didn't most devs basically just treat the 486 as a faster 386?
Q2 doesn't rely on specific Pentium instructions to function. Neither does Q3A. I've had both of those games going on a 486 before. I even tried OpenArena on one.
So............there!
The games that WILL FAIL on a 486 are those who issue a timestamp clock instruction to evaluate teh mhz. like FF7PC
wrote:Q2 doesn't rely on specific Pentium instructions to function. Neither does Q3A. I've had both of those games going on a 486 before. I even tried OpenArena on one.
I wonder, would it be possible to NOP that instruction using a debugger like SoftICE to get FF7 running on a 486?
On that topic, back in the yonder days I was unable to play X-Wing vs TIE Fighter on my Am5x86 because it would always lock up within a minute or so in the flight engine. I assumed it was because the game requires a Pentium.
wrote:On that topic, back in the yonder days I was unable to play X-Wing vs TIE Fighter on my Am5x86 because it would always lock up within a minute or so in the flight engine. I assumed it was because the game requires a Pentium.
Have you ever tried playing it with a POD to see if that really was the problem?
wrote:Have you ever tried playing it with a POD to see if that really was the problem?
Back then I didn't have a POD around to try. Right now I don't have any 486 boards so can't test.
wrote:Only the 486SX (and 386SX too. Yes a 386dx can run Quake)
386SX 16Mhz does run Quake with FPU ;D
I've run Quake 1 and Grand Theft Auto on 386DX40 + FPU.
Getting it to run and seeing it with your own eyes, is an achievement on it's own. I love to try those things out.
I actually have win95 on my 386 for testing purposes... i think i can try quake 2 on it. 😁
(Looking at topic's heading, i think 386 is really ot here?)
