Duke Nukem II wont run
First post, by Soupdragon
I just finished putting together a 486 pc. All the games I have tried run ok but I cant get Duke II to start the screen just goes blank and I have to push the reset button to use the pc again. Its the Duke II release from the Duke 3D CD-ROM.
PC specs:
Am486 DX4-120
ASUS PVI-486SP3
32MB
Diamond Stealth 64 Video 2001 1MB PCI
Sound Blaster Pro 2.0
MS-DOS 6.22
Autoexec.bat
@ECHO OFF
PROMPT $P$G
SET PATH=C:\DOS
SET TEMP=C:\TEMP
SET DIRCMD=/O
SET SOUND=C:\SBPRO
SET BLASTER=A220 I5 D1 T4
LH C:\DOS\MSCDEX.EXE /D:CDROM1
LH C:\DOS\KEYB UK,,C:\DOS\KEYBOARD.SYS
LH C:\DOS\DOSKEY.COM
C:\CTMOUSE\CTMOUSE.EXE
C:\SBPRO\SBP-SET /M:12 /VOC:12 /CD:12 /FM:12
Config.sys
SWITCHES /F
DEVICE=C:\DOS\HIMEM.SYS /TESTMEM:OFF
DOS=HIGH,UMB
DEVICE=C:\DOS\EMM386.EXE RAM AUTO
DEVICEHIGH=C:\CDROM\QCDROM.SYS /D:CDROM1
COUNTRY=044,,C:\DOS\COUNTRY.SYS
FILES=40
BUFFERS=40
STACKS=9,256
LASTDRIVE=E
FCBS=4,0
Thanks
Reply 1 of 24, by badmojo
You have some things in your config which I'm not familiar with (keyboard.sys, country.sys), have you tried booting with a boot disk (i.e. no config) and running it?
Reply 2 of 24, by vetz
Everyone with localized keyboards use this (I have my computers set to country code 047). Highly doubt it is causing the issues. Testing with a minimal boot could be an idea though .
Reply 3 of 24, by Spikey
I would surely delete some things in that autoexec.bat! I seem to remember mine having less than 10 lines..
For fun, you might unplug the sound card, or backup autoexec and delete references to SBPRO, and see if it's a sound card issue, that often seems to be the thing.
Question: Can you run other Apogee titles of the era, e.g. Monster Bash, Hocus Pocus (even the free demos)?
Reply 4 of 24, by Soupdragon
Good suggestions but running minimum start-up files didn't fix it.
I tested Secret Agent, Monster Bash, Bio Menace, Alien Carnage, Crystal Caves, Hocus Pocus, Commander Keen 4, Duke Nukem 1 and Wacky Wheels and they all run ok.
One odd thing both Bio Menace and Keen 4 wont start they just hang on the press any key screen unless I move the serial mouse. Pressing a keyboard button doesn't work. If I disable the serial port in the bios or leave the mouse unplugged it doesn't happen. I have a ordered a ps2 port header from ebay so I hope that will fix that one.
Strange Duke II wont work my DX2-66 PC and DOSBox run it no problem.
Reply 5 of 24, by Joey_sw
perhaps defective duke2 installation?
-fffuuu
Reply 6 of 24, by Davros
Is it a vesa problem ?
have you tried univbe ?
Reply 7 of 24, by Soupdragon
More good suggestions. Tried a shareware install of the game and also using univbe still blank screen. 😵
Reply 8 of 24, by Spikey
Mouse unplugged affect Duke 2?
Reply 9 of 24, by Soupdragon
Unfortunately not. 🙁
Reply 10 of 24, by Jorpho
The game has an external sound configuration utility, right? Does everything work correctly there?
This sounds like it might feasibly be an IRQ conflict of some sort. Maybe if there's a parallel port you're not using, you can disable that in your BIOS and move your SBPro to IRQ7?
Reply 11 of 24, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Maybe set DN2 to no sound in DOSBox and copy it over again
1+1=10
Reply 12 of 24, by Soupdragon
I tried disabling the parallel port and changing the jumpers on the sound blaster to IRQ 7. That didn't help.
What did fix it was swapping the video card out. I first tried a PCI Diamond Stealth 3D 2000 Pro that didn't work (maybe because it shares the same 2D core as the Stealth 64 Video 2001). I then tried a generic Cirrus Logic vl-bus card that did work.
Its odd as the 3D 2000 Pro runs duke 2 fine in my Pentium pc. Guess its just a small incompatibility with this mainboard.
Steam | World of Warcraft
Reply 13 of 24, by Malik
I tested Duke Nukem II Shareware last night after reading this post in my 486.
The specs are :
intel 486DX2-66 with 16MB RAM
AOpen motherboard which shares the same chipset with the SP3,
Diamond Stealth 3D 2000 Pro 4MB
SBAWE32 with LAPC-I
MS-DOS 6.22
tested with the EMS setting enabled.
There's no problem playing it. My sound card is set at IRQ5, and sound works.
Not sure why your Stealth 3D 2000 Pro is not working in that system.
Maybe the CPU and FSB settings are conflicting with this game? I used to have random lockups in some DOS games when the bus speed is not a 33MHz or a multiple of it - a thing I noticed even in later Pentiums - upto Pentium III.
Reply 14 of 24, by Soupdragon
It's both my Diamond Stealth 64 Video 2001 and Diamond Stealth 3D 2000 Pro that wont run duke 2 when in the system.
I set the bus speed back from 40MHz to 33MHz. I then spent a couple of hours trying each bios chipset setting at each value still cant get it to load the game.
Annoying as one of the reasons I bought the PCI mainboard was because I was having trouble finding a good vl-bus graphics card for my old one.
Reply 15 of 24, by White
In a game settings try to switch sound card to adlib. I have same problem and two things helped me:
1. Change AWE 32 CT-3900 to AWE 64 Gold
2. Without changing AWE 32 CT-3900 i switched sound to AdLib
Reply 16 of 24, by J3SteR727
Sorry to bring up a old thread but im having the same issues. I can run the shareware version fine. But once I install the full game and run Nukem2.exe It just turns black and nothing happens. I tried everything I could think of but nothing works. If I swap the shareware .exe in , it works but is still the shareware version. My system is as follows...
Zida Tomato 4DPS Version 2.1
AMD AM5 X86 @ 133mhz
ATI Mach 64 video card
16MB ram
Reply 17 of 24, by J3SteR727
Forgot to mention my sound card is a Creative SoundBBlaster 16 Vibra XV. I tried disabling all music and sound and still no luck 🙁
Reply 18 of 24, by akula65
Since you are using an ATI mach64 card, it might pay to see if ATI's M64VBE gives better results. M64VBE is a DOS TSR released by ATI to support the VESA BIOS Extension 2.0. A number of games needed it in order for mach64s or mach64 variants to work properly. Amtex released a patch for Royal Flush Pinball that was just a repackage of M64VBE to make it work on mach64-based cards. I also remember having to use M64VBE with a 264VT-based motherboard to get Flight Unlimited to work (only 1/4 of the screen was used for display without M64VBE).
This site seems to have a package with M64VBE, although I have no idea what the latest version is:
http://ftp.isu.edu.tw/pub/Hardware/multimedia … CT/64vbe210.txt
http://ftp.isu.edu.tw/pub/Hardware/multimedia … CT/64vbe210.exe
This directory may have other releases:
http://ftp.isu.edu.tw/pub/Hardware/multimedia … I/MACH64_GX_CT/
Perhaps others who still use a mach64-variant can tell you what the latest version of M64VBE is as I have not used it for many years.
Note that you may have to use a particular set of M64VBE command line switches to get a particular game to work properly, so experimentation may be necessary.
Reply 19 of 24, by J3SteR727
Thanks for the respons! If I were to move to the next generation of ATI card ( 3d rage) would I have the same problem?
