First post, by AdamP
I recently got the CD version of Theme Park. The game works, but I'm having sound issues. Specifically, the Sound Blaster 16 driver doesn't work (I'm using a CT4540 AWE64 Gold. I also tried it on a CT4760 SB Live! and it didn't work on that either). The Sound Blaster, Sound Blaster Compatible, and Sound Blaster Pro drivers all work, but then the game sometimes just freezes on startup, which doesn't happen with the Sound Blaster 16 driver. In DOS, I just get silence using the SB16 driver, but in Windows I get a strange noise (listen to the attached file). None of this happened on the floppy version; it all just worked, SB16 driver and all. The only thing I can think of is the SB16 driver actually reads "Soundblaster 16 ASP", not just "Soundblaster 16", so I'm guessing this version of the game needs the ASP/CSP (which neither the CT4540 or the CT4760's emulated SB16 have) for it to work at all (the floppy version also read "Soundblaster 16 ASP" and it worked there). The music works fine with no problems.
I'm currently using these seetings:
SOUNDFX = SBPRO 220 5 1MUSIC = SBAWE32 330 0 0
The floppy version works fine with these settings:
SOUNDFX = SB16 220 5 1MUSIC = GENERAL 330 0 0
Autoexec.bat:
REM - By Windows Setup - set ieppp=C:\MSIE5REM - By Windows Setup - set pctcp=C:\MSIE5\pctcp.shvREM - by MS DLC 32 - C:\WINDOWS\dlchlp.exeSET CTCM=C:\CTCMrem SET CTCM=C:\CTCMecho offrem C:\WIN3\net startSET BLASTER=A220 I5 D1 H5 P330 E620 T6rem C:\CTCM\CTCU /S /W=C:\WINDOWSSET MGA=C:\MGA\SETUP\mode con codepage prepare=((437) C:\WINDOWS\COMMAND\ega.cpi)mode con codepage select=437LH keyb uk,,C:\WINDOWS\COMMAND\keyboard.sysSET SOUND=C:\SB16SET MIDI=SYNTH:1 MAP:G MODE:0rem C:\SB16\AWEUTIL /Srem SET PATH=%PATH%;C:\PROGRA~1\BORLAND\DELPHI5\BIN;C:\PROGRA~1\BORLAND\DELPHI5\PROJECTS\BPLrem PATH=C:\WIN3;%PATH%GOTO %config%:Networkset screenthief=C:\st /com-path=C:\win3;C:\networkC:\dos\powerLH /L:0 C:\windows\command\smartdrv.exe /vLH /L:0;1,3312;2,42880 /S command /c C:\windows\dosstart.batrem C:\windows\CTCU /S /W=C:\WIN3rem C:\SB16\DIAGNOSE /S /W=C:\WIN3C:\SB16\MIXERSET /PLH /L:0 command /c C:\windows\startnet.batgoto end:MinimalC:\windows\command\MSCDEX.EXE /S /D:mscd001set temp=C:\temp:NoNetwork:End
Config,sys
[Menu]menuitem=NoNetworkmenuitem=Networkmenuitem=Minimal[common];DEVICE=C:\CTCM\CTCM.EXEDEVICE=C:\WINDOWS\himem.sys /testmem:off /cpuclock:off /machine:1 /vDEVICE=C:\WINDOWS\EMM386.EXE NOEMS HIGHSCAN I=B000-B7FF d=48 WIN=B300-B7FF;DEVICE=C:\windows\command\smartdrv.exe /double_bufferbuffers=30,0files=45dos=UMBLASTDRIVE=EFCBS=4,0switches=/f /eDEVICEHIGH /L:2,17184 =C:\WINDOWS\COMMAND\DISPLAY.SYS CON=(EGA,,1)Country=044,437,C:\WINDOWS\COMMAND\country.sys;devicehigh=C:\usbaspi.sys /v /w;devicehigh=C:\usbcd.sys /d:usbcd001;devicehigh=C:\di1000dd.sys;device=C:\NETWORK\ifshlp.sys;LASTDRIVE=Z;DEVICE=C:\WIN3\SMARTDRV.EXE /DOUBLE_BUFFER;DEVICE=C:\SB16\DRV\CTSB16.SYS /UNIT=0 /WIN95 /BLASTER=A:220 I:5 D:1 H:5;DEVICE=C:\SB16\DRV\CTMMSYS.SYS;devicehigh=C:\sb16\drv\csp.sys /unit=0 /blaster=a:220[network]dos=HIGHDEVICEHIGH /L:2,40800 =C:\OAK\OAKCDROM.SYS /D:MSCD001DEVICEHIGH /L:2,16976 =C:\WINDOWS\SETVER.EXE;DEVICEHIGH=C:\plugplay\drivers\dos\dwcfgmg.sysREM ** ;DEVICE=C:\windows\CTCM.EXE;devicehigh=C:\windows\command\ansi.sysStacks=9,256REM ** ;DEVICE=C:\windows\CTCM.EXEDEVICEHIGH /L:0;2,8112 /S =C:\DOS\POWER.EXEDEVICEHIGH /L:1,4560 =C:\WIN3\IFSHLP.SYSinstall=C:\share.exe[NoNetwork]dos=HIGH,autoStacks=64,512DEVICE=C:\windows\setver.exeREM ** ;DEVICE=C:\windows\CTCM.EXE;devicehigh=C:\windows\command\ansi.sys[minimal]dos=high,umb,noautoDEVICE=C:\windows\setver.exeDEVICE=C:\oak\oakcdrom.sys /D:mscd001
Does anyone have any ideas about this?
Thanks
