First post, by Jolaes76
I have several 286 motherboards that act like this:
with a perfect Tadyran external battery attached, the CMOS settings can be saved and kept, including date and time. Well, as long as there is no HDD controller card or multi I/O card of any sort in the motherboard...
When Winbond, LG, Acer based IDE multi I/O controllers are present or I put in an AHA-1542 SCSI card, CMOS checksum errors come up at boot and settings are re-set to BIOS defaults.
The batteries I tried are surely healthy. What on earth is this then? Do my motherboards have some sort of power leak - ie, some ISA cards suck out all the juice at startup from the RTC... ?
286/XT gurus, please help!
"Ita in vita ut in lusu alae pessima iactura arte corrigenda est."
Reply 1 of 2, by Markk
That sounds familiar with the symptoms I got on a 286 while I was trying to install some hardware that seemed either incompatible for some reason(a specific controller I think), or faulty(a hard disk with some serious issues that didn't work). I remember that when I removed that piece of hardware the system worked as it should.
Reply 2 of 2, by Jolaes76
Thanks, this confirms my suspicion...
Yet, it is strange that these Headland based 286 motherboards are so allergic to many types of HDD controllers. I hope I will find one that do not reset the CMOS.
