TSR Text Editor?
First post, by Ze_ro
I don't know if something like this exists, but I'm looking to find a text editor that can run in the background that I can switch to from within DOS games, for example to read a walkthrough or moves list... or keep notes while playing an RPG. Doesn't have to be anything fancy, as long as it can load/edit/save .txt files and not corrupt the video display in the process.
I tried searching the web, but "dos tsr text editor" just seems too generic. Any suggestions?
--Zero
Reply 1 of 8, by Jorpho
I very much doubt there is something that will work with all games and all video modes. DOS just doesn't work like that.
You can always resort to something like Windows 3.x or even DESQView.
Reply 2 of 8, by leileilol
NoteTaker comes close.
FUCK "AI"
Reply 4 of 8, by idspispopd
Well, "dos" "tsr" "text editor" finds some stuff.
For example Borland Sidekick, or SemWare QEdit (-> http://files.mpoli.fi/unpacked/software/dos/e … ors/qedit4.zip/).
I don't know if those will play along with different graphics modes. Sound could also hang or loop. And I don't know if they would work with protected mode games, games which do their own keyboard handling etc.
Therefore I second Jorpho's suggestion to use a task switcher (except if you are on an XT which can't run any).
Reply 5 of 8, by Ze_ro
So I tried out QEdit and NoteTaker... unfortunately, while QEdit allows you to exit to a shell, I couldn't find any option to get back into the text editor without completely exiting the shell. NoteTaker seemed a lot more appropriate, but it's hotkey doesn't seem to work from within games... seems like it would work nicely within text applications perhaps.
As much as I hate to admit it, Windows 3.1 actually worked fairly well, and seems like the best option. I seem to recall having a lot of trouble running games under Windows back when I was younger, but the two main games I wanted this ability for (One Must Fall 2097 and Ultima VI) both worked fine, except for stuck notes on my MT-32, but I kinda expected that.
I'll have to try out DesqView some day...
--Zero
Reply 6 of 8, by Joey_sw
most TSR intercept the bios/dos interrupts for the 'hook',
but for games that use its own keyboard handler in most case the hook wont work.
-fffuuu
Reply 7 of 8, by Malik
Perhaps use DOSSHELL from MS-DOS 5.0 or MS-DOS 6.22 Supplemental Disk to load the game in question and use the task switcher to switch back to use the text editor within the DOSSHELL?
Compatibility wise, it's much better than running with Windows 3.x, but DOSSHELL itself eats a considerable chunk of the conventional memory.
Reply 8 of 8, by Jorpho
There's also TASKMAX from DR-DOS 6, for that matter.
