First post, by Jan3Sobieski
I posted this on another forum but haven't gotten any responses, figured maybe someone here would help.
I found a Thomson 4460D EGA monitor at a thrift store. Took it home, started it up, works fine, but... No red color.
I tried hitting it, tapping, didn't work. Played around with the cable, checked pins, all the usual stuff. No dice. The monitor has a 4 way switch that goes from multicolor/green only/red only/blue only.
- Multicolor option shows all colors but red
- Green only - shows green
- Blue only - shows blue
- Red only - shows green
Color white is displayed correctly. Just red/light red/brown/light brown are not shown correctly
I took it apart to look for bad solder joints but couldn't find any. I don't see any bulging capacitors.
There are three boards inside the monitor. One that lays flat on the bottom (looks like power related) one on the side where the signal cable goes to and a third board that's hooked up to the back of the electron gun.
Please see photos here http://imgur.com/a/B2ihV
On the first photo, there are three knobs on top. Left one controls brightness, middle one controls intensity and the right one switches from the various modes I mentioned earlier. (It looks like photo 4 shows two caps bulging, but they're really not. They're nice and flat.)
At this point I'm ready to throw it in the dumpster but feel really bad as this monitor was one of the best ones out there back in the day. http://books.google.com/books?id=voPUUGTC56UC … epage&q&f=false
Any help? 🙁
Reply 1 of 9, by JaNoZ
Are you sure that there are no solder cracks?.
Also did you measure that all the signals from the ega cable arrives to the monitor.
If you have the monitor put together did you try to bend the ega cable from front to end in different angles to try see if there is some disconnection there.
Also the caps could be bad even if they look ok, did you try if it helps to heatup all the capacitors with blowdryer while in use.
Be sure to heatup very hot all the capacitors and see if it regains the red color, or after a restart.
Reply 2 of 9, by keropi
Personally after a visual inspection I would just find an old tv technician and have the monitor serviced.... not much of an answer but there is a gazillion things that could be wrong with the monitor and we just guess... crts not showing one color was a common fault, should be easy for a skilled person to figure out the damage
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 3 of 9, by cdoublejj
keropi makes a good point, i understand what he is saying after i tried to revive and old projection screen TV (3 CRTS), i really count do any thing to fix it. no manual or guide could help, i even had the help of a retired TV technician and it still didn't work.
Reply 4 of 9, by Anonymous Coward
Try vintage-computer.com forums. There are a number of seasoned engineers in there and monitor repair is a fairly common topic.
Reply 5 of 9, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
First thing to check would be bad solder joints at the tube socket. Another thing to try: turn brightness all the way up. Will the background become white or cyan?
1+1=10
Reply 6 of 9, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Oh, so white works, ignore my comment above. The issue is likely on the logic board (first picture).
- a resistor could be broken
- the glue for the resistors is known to eat through traces
- or a trace is broken otherwise
- bad solder joints are not always visible
- one of the logic ICs may be bad
1+1=10
Reply 7 of 9, by Jan3Sobieski
Thank you all for your replies
Also did you measure that all the signals from the ega cable arrives at the monitor.
I can't be 100% completely sure, but visual inspection did not reveal any obvious ones. I did measure the signal for all pins and they do arrive to the other end
See above.
Are you saying bad capacitors start working again if heated up?
The problem for me is finding a shop that would do it. Most electronics stores don't service stuff this old. I'd have to find an "older" shop. I have one in my city but the guy said he charges $60 just to take a look at it with no guarantee of finding the problem.
Exactly.
Thanks, I'll try there as well.
h-a-l-9000 wrote:
Oh, so white works, ignore my comment above. The issue is likely on the logic board (first picture). - a resistor could be brok […]
Can all of these IC's simply be replaced? What about the TDA3506M specifically? Is this just swappable with another one? Or is it programmed in some way first?
I will try and resolder all connections and replace all caps, see if that helps at all. I feel so bad about throwing it out 🙁
Reply 8 of 9, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Since you get white the TDA3506M is not at fault. It's not a logic IC 😉. It controls the electron guns. Somehow the signal has to make its way from the input to the TDA3506. Red is lost on the way when it's the only active color. Your EGA card and cable are known good?
Capacitor problems show different symptoms.
1+1=10
Reply 9 of 9, by Jan3Sobieski
This is why I'm confused. When the switch is set to "Auto" , I can see white text. While in that mode, if I go do a color test in dos, All colors are there except Red/light red, brown/light brown. If the red color is completely missing, why is the white text, well, white? Shouldn't all three color guns fire to produce white?
I tried several EGA cards, same result, I even opened a new one just to make sure and like I mentioned above, I did a continuity test on the cable with a multimeter and signal from all pins safely arrives at the logic board.
