Tetra Music Compositor.
Reply 20 of 66, by rfnagel
Hey Malik (and All),
Attached is a ZIP containing sample disk ST-01, all files renamed, and with the proper edited "LISTING.TXT" file (what a PITA!) for use with Tetra Compositor 😀
(EDIT) See three messages below for the attachment!
Rich ¥Weeds¥ Nagel
http://www.richnagel.net
Reply 22 of 66, by rfnagel
Hmm... somehow I TOTALLY screwed up! That "LISTING.TXT" file that I created for the renamed samples (and was a real PITA to create) didn't get zipped up with the pack... and I've ALREADY deleted the samples and TXT file <aarrggh>!
I'll have to recreate the pack again, and I'll try to upload the fixed pack later today <ugh>.
Rich ¥Weeds¥ Nagel
Reply 23 of 66, by rfnagel
...and, it's FIXED! 😀
P.S. Now included are ALL of the ST-01 through ST-05 sample disks, ready for use with Tetra Compositor... and YES, I included the proper "LISTING.TXT" files this time! 😀
P.P.S. The included readme:
Tetra Compositor Ultimate SoundTracker Sample Disks (Rev. C)
"Ultimate SoundTracker" was a "Tracker" format music composing program for
Amiga computers, and was coded and released by Karsten Obarski back in 1987.
The program shipped with an additional five floppy disks ("ST-01" through
"ST-05") that contained instrument samples for composing Tracker format music
using the program.
The files included in this archive were all of the samples that were included
with these five sample disks, and have been renamed for use with Bram
Graveland's excellent "Tetra Compositor" for DOS Tracker format music composing
program (released back in 1991).
Note that each of the sample disks have been organized by subdirectory within
the archive, and that each of the sample disks also have a proper "LISTING.TXT"
file (which is required when using the samples with Tetra Compositor). Lastly,
note that each of the sample files are raw 8-bit signed PCM ".NTI" format
files.
Rich ¥Weeds¥ Nagel
Reply 25 of 66, by rfnagel
Folks,
I just updated the Tetra_Compositor_Ultimate_SoundTracker_Sample_Disks.zip file (two messages above), so you might want to re-download it.
I was compiling a pack of the sample disks (as well as the samples included with Tetra Compositor) that were renamed with regular DOS short filenames (for use with any DOS tracker), and I found a problem:
25 of th samples included with the sample disks were in "IFF" format, and NOT regular raw format. This causes problems with Tetra Compositor, as well as most any other DOS tracker that doesn't support "IFF" format samples (weird clicks and such when the Tracker tries to play back the info data/header contained within those specific samples).
Anyhow, I've converted those 25 samples to regular raw format (headerless 8-bit mono signed PCM sample files) 😀
Rich ¥Weeds¥ Nagel
Reply 26 of 66, by rfnagel
Folks,
Here are all of the Tetra Compositor sample files and Ultimate SoundTracker sample disks, all nicely renamed with descriptive short filenames for use with most any DOS Tracker 😀
Note that these ALSO include my fix mentioned directly above (which is when I discovered the problem detailed above... when I was compiling THIS pack).
DOS Tracker Tetra Compositor and Ultimate SoundTracker Sample Disks (Rev. C)
"Tetra Compositor" was a "Tracker" format music composing program for DOS
computers, and was coded and released by Bram Graveland back in 1991. The
program shipped with set of 61 instrument samples for composing Tracker format
music using the program.
using the program.
with Tetra Compositor, as well as all of the samples that were included with
the five sample disks that were included with Ultimate SoundTracker, and have
been renamed using descriptive short filenames for use with most any DOS
Tracker format music composing program.
the archive, and that each of the sample files are raw 8-bit signed PCM ".SAM"
format files.
Rich ¥Weeds¥ Nagel
Reply 27 of 66, by rfnagel
Folks,
Attached is a ZIP containing Fast Tracker II v2.09a, as well as a pre-configured version of DOSBox v0.72 that includes a MIDI input patch (downloaded from here in the forum).
From the included readme:
Fast Tracker II v2.09a and DOSBox v0.72 MIDI Input Patch
The files included in this archive consist of an installation of "Fast Tracker
II v2.09a", which was a "Tracker" format music composing program for DOS, and
was updated and released by Magnus Högdahl and Fredrik Huss of the demo group
"Triton" back in 1999.
Also included is an installation of DOSBox version 0.72 that has been patched
to enable MIDI input functions when running Fast Tracker II, as well as several
handy Windows start menu shortcuts for your Windows desktop (or start menu).
Both programs have been optimally pre-configured to run "out of the box" on
most computers, with only a few minor configuration changes to DOSBox:
1) Unzip the "SBLive" directory contained in the
"Fast_Tracker_II_v2.09a_and_DOSBox_v0.72_MIDI_Input_Patch.zip" archive to
the root of your hard drive, maintaining the directory structure of the
archive in verbatim.
2) Unzip the included Windows shortcuts contained in the "Start Menu" directory
in the "Fast_Tracker_II_v2.09a_and_DOSBox_v0.72_MIDI_Input_Patch.zip"
archive to the usual location on your hard drive in verbatim.
3) Edit the DOSBox configuration file "DOSBox.conf" (located in the
"C:\SBLive\Fast Tracker II\DOSBox" directory) using Windows Notepad to
select the proper MIDI input device (usually "inconfig=0").
Refer to the "DOSBox v0.72 MIDI Input Patch Devices.txt" file (located in
the "C:\SBLive\Fast Tracker II\DOSBox\Documentation" directory) for more
information about configuring the MIDI input and output devices for this
patched version 0.72 of DOSBox.
4) Click the "Fast Tracker II" icon, and then begin composing some awesome
retro tracker music!
The following is a brief description of the directories located in the Fast
Tracker II installation directory:
FASTRACK\CONFIG = This directory contains a backup of the archive's default
Fast Tracker II configuration files.
FASTRACK\DOCS = Refer to the files contained in this directory for detailed
Fast Tracker II documentation, help, information, and
manuals.
FASTRACK\SAM = Copy your digital "IFF", "RAW", "SAM", "SMP", and "WAV"
format sample files to this directory. Note that your "RAW",
"SAM", and "SMP" sample files should be in raw 8-bit signed
"PCM" format to be compatible with Fast Tracker II.
FASTRACK\XI = Copy your Fast Tracker II "XI" format instrument files to
this directory.
FASTRACK\XM = Copy your "MOD" and Fast Tracker II "XM" format module files
to this directory.
FASTRACK\XP = Copy your Fast Tracker II "XP" format pattern files to this
directory.
FASTRACK\XT = Copy your Fast Tracker II "XT" format track files to this
directory.
Note that the DOSBox keymapper file "Mapper.txt" has been slightly edited in
order to prevent conflicts when using the keyboard shortcuts that Fast Tracker
II supports. Simply press the "SHIFT" key on your keyboard, in conjunction with
the usual DOSBox keyboard shortcuts:
Show last 42 lines
SHIFT+ALT+ENTER = Switch to full screen and back.
SHIFT+ALT+PAUSE = Pause emulation.
SHIFT+CTRL+F4 = Change between mounted disk-images, update directory cache
for all drives.
SHIFT+CTRL+ALT+F5 = Start/Stop creating a movie of the screen (AVI video
capturing).
SHIFT+CTRL+F5 = Save a screenshot (PNG).
SHIFT+CTRL+F6 = Start/Stop recording sound output to a wave file.
SHIFT+CTRL+ALT+F7 = Start/Stop recording of OPL commands.
SHIFT+CTRL+ALT+F8 = Start/Stop the recording of raw MIDI commands.
SHIFT+CTRL+F7 = Decrease Frameskip.
SHIFT+CTRL+F8 = Increase Frameskip.
SHIFT+CTRL+F9 = Terminate DOSBox.
SHIFT+CTRL+F10 = Capture/Release the mouse cursor.
SHIFT+CTRL+F11 = Slow down emulation (Decrease DOSBox Cycles).
SHIFT+CTRL+F12 = Speed up emulation (Increase DOSBox Cycles).
SHIFT+ALT+F12 = Unlock speed (Turbo button).
Also note that I have set Fast Tracker II's predefined "Panning Envelopes"
(which can be found within Fast Tracker II's "Instrument Edit" screen) to the
following:
Predefined 1 = Default Fast Tracker II Panning Envelopes 1 through 6.
Predefined 2 = 100% Left Panning Envelope.
Predefined 3 = 050% Left Panning Envelope.
Predefined 4 = 000% Centered Panning Envelope.
Predefined 5 = 050% Right Panning Envelope.
Predefined 6 = 100% Right Panning Envelope.
This is to assist with composing standard Amiga 4-channel "Ultimate
SoundTracker" or "ProTracker" "MOD" format modules. On an Amiga computer
running the Ultimate SoundTracker or ProTracker music composing programs, the
four channels are hard-panned to the following:
Channel 1 = Left (Lead)
Channel 2 = Right (Accompaniment)
Channel 3 = Right (Bass)
Channel 4 = Left (Percussion)
Lastly, note that the preset "User Defined" color scheme is of my own creation,
and is how I've been using Fast Tracker II for well over a decade :)
Of course, this whole schmear works GREAT with the DOS_Tracker_Tetra_Compositor_and_Ultimate_SoundTracker_Sample_Disks.zip" sample pack that I uploaded previously 😀
P.S. Why the "inconfig=4" in the "DOSBox.conf" file (that you'll probably need to edit), as well as the "SBLive" directory in the ZIP (that FYI, all of the WIndows shortcuts point to)? Simply because that's how it is on my PC <grin> 😀
P.P.S. This whole schmear in action -> https://www.youtube.com/watch?v=hu6YIkZtkv4 😀
Rich ¥Weeds¥ Nagel
Reply 28 of 66, by rfnagel
Hehe, been messing around with Fast Tracker 2 for a short time (with all of it's options set to be as Amiga ProTracker compatible as possible), and the above-said ST-## sample disks... and here is the resulting ".MOD" file:
"Lamer!"
An EXTREMELY lame Tracker song!
4-channel L-R-R-L retro goodness 🤣! 😀
    LAMER!.ZIP
    17.01 KiB
    83 downloads
Rich ¥Weeds¥ Nagel
Reply 30 of 66, by rfnagel
Malik wrote:
Nice and clean. Hehehe..
Hehe, and have a looksie at sample names <grin> 😀
Rich ¥Weeds¥ Nagel
Reply 31 of 66, by rfnagel
Attached is a ZIP contianing my new Techno "MOD" format "Tracker" song, "Not Enough Sleep!"... which is what I was severely lacking when I composed this song last night!
P.S. A video of Fast Tracker II playing the tune here -> https://www.youtube.com/watch?v=hu6YIkZtkv4 .
P.P.S. Not quite as lame as "Lamer!" above 🤣! 😀
    NoSleep.zip
    137.08 KiB
    81 downloads
Rich ¥Weeds¥ Nagel
Reply 32 of 66, by rfnagel
Hehe, my own custom color schemes for Fast Tracker II (that I've used for over a decade), as well as MilkyTracker (well, as close as I can get MT to looking like FT2 <grin>) 😀
    10.09 KiB
    26.3 KiB
Rich ¥Weeds¥ Nagel
Reply 33 of 66, by rfnagel
Folks,
Similar to my "DOS_Tracker_Tetra_Compositor_and_Ultimate_SoundTracker_Sample_Disks.zip" archive above, here are all of the Tetra Compositor sample files and Ultimate SoundTracker sample disks, all nicely renamed with descriptive LONG filenames for use with most any Windows Tracker 😀
Windows Tracker Tetra Compositor and Ultimate SoundTracker Sample Disks
using the program.
been renamed using descriptive long filenames for use with most any Windows
the archive, and that each of the sample files are raw 8-bit signed PCM ".8svx"
format files.
Rich ¥Weeds¥ Nagel
Reply 34 of 66, by rfnagel
Folks,
Attached is a ZIP containing my first "Chiptune" styled Tracker song, "The Gayme Boy". The song uses only three basic waveforms (à la Nintendo GameBoy DMG-01 style), and is some (new) retro GameBoy music goodness at it's best 😀
P.S. A video of Fast Tracker II playing the tune here -> http://www.youtube.com/watch?v=bkzyjZw44sE (note that the attached ZIP below is a slightly extended version of the YouTube video).
P.P.S. For all of the "PC Police" (although, I could NOT CARE LESS), "Gay" = "HAPPY" 😀
(edit: grammar fixed 😀 )
    GaymeBoy.zip
    3.72 KiB
    77 downloads
Rich ¥Weeds¥ Nagel
Reply 35 of 66, by badmojo
rfnagel wrote:
P.P.S. For all of the "PC Police" (although I could CARE LESS), "Gay" = "HAPPY" 😀
Sorry this is not even close to on topic, but I've often wondered why Americans say "could care less" when they seem to mean "couldn't care less", and so I'm taking this opportunity to ask!
So what's with that? Is it sarcasm, and you really could not care less, or do you still have a little bit of care left for the PC Police? 😕
Reply 36 of 66, by rfnagel
Hehe you are correct about my incorrect grammar... I should have said "could not" <grin> 😀
Rich ¥Weeds¥ Nagel
Reply 37 of 66, by badmojo
Sorry mate, there you were trying to appease the PC Police, only to be pulled up by a Grammar Nazi! My apologies.
Reply 38 of 66, by rfnagel
No problem at all 🤣! While I could not care less about the PC Police (hehe, I got it right that time), I have a big pet peeve about grammar 😀
Rich ¥Weeds¥ Nagel
Reply 39 of 66, by rfnagel
rfnagel wrote:
Now... is your Tracker music collection lacking? Fret now more, surf here: […]
SoundMOD Volume One by Data Express, Inc., 1994
http://archive.org/details/cdrom-soundmod-vol2-dataexpress
http://archive.org/download/cdrom-soundmod-vo … dataexpress.iso
SoundMOD Volume Two by Data Express, Inc., 1995
AND, Even MORE for your Tracker music collection, the "MODs Anthology"... 4 CDs worth! 😀
http://archive.org/details/cdrom-amiga-mods-anthology-1
http://archive.org/download/cdrom-amiga-mods- … odk.mcsteam.iso
http://archive.org/details/cdrom-amiga-mods-anthology-2
http://archive.org/details/cdrom-amiga-mods-anthology-3
http://archive.org/details/cdrom-amiga-mods-anthology-4
P.S. Here are lists of all of the artists amd modules included on the four CDs:
hlsite.free.fr/modsanth/list_authors(a-f).html
hlsite.free.fr/modsanth/list_authors(g-q).html
hlsite.free.fr/modsanth/list_authors(r-z).html
http://hlsite.free.fr/modsanth/list_groups.html
http://hlsite.free.fr/modsanth/list_misc.html
http://hlsite.free.fr/modsanth/list_synth.html
http://hlsite.free.fr/modsanth/oldies_forever.html
Rich ¥Weeds¥ Nagel
